Author Topic: Easy cheap fix for my hood sticking up in back  (Read 15658 times)
Offline Tater502
« on: February 24, 2010, 10:11:31 am »
The hood on my 79 sierra grande was sticking up above the fenders probably 2 inches back by the windshield. I know my hinges probably need replaced, but this took about 10 minutes to fix.
I unbolted the front hinge to hood bolts and put a few thick washers between the hood and hinge. I had to use longer bolts, but now my hood is almost even with the fenders.
"If you loosen the FRONT bolt on the hood (where it bolts to the hinge) and put a shim, or washer between the hood and hinge, this will LOWER the hood on that side. If you put that same washer under the rear bolt it will RAISE the rear of the hood on that side."
Got the info here http://www.autobody101.com/articles/article.php?title=Body%20Panel%20Alignment
Andy
Offline MarkS
Re: Easy cheap fix for my hood sticking up in back
« Reply #1 on: March 03, 2010, 09:22:09 pm »
Hey in these times we have to find creative ways to fix issues. I lose sleep at night (I know it's something we have to live with on the square bodies) on things like body alignment. I wonder if the washer fix stands out? Got pics?
« Reply #2 on: March 03, 2010, 09:24:43 pm »
I just ordered a new set of hinges, they're cheap enough. For something that's not going to be a show piece I would just repair them with a shoulder bolt.
Offline 1980c10
« Reply #3 on: March 03, 2010, 09:28:22 pm »
going to have to try that. If it doesn't work; Vile where did you find hinges?
« Reply #4 on: March 03, 2010, 09:36:06 pm »
« Reply #5 on: March 04, 2010, 01:20:59 am »
Yes I can get them.  I am a distributor for Goodmark, but those are backordered.  I can get anything Goodmark sells.
Offline Tater502
« Reply #6 on: March 04, 2010, 08:24:49 pm »
I can get some pics this weekend sometime. I will eventually get new hinges, but this is a quick fix to get the truck looking better.
Andy
« Reply #7 on: March 04, 2010, 10:09:50 pm »
Chris let me know if you get them in the catalog. I'm probably going to order 2 sets.
Offline 1980c10
« Reply #8 on: March 04, 2010, 10:26:58 pm »
cool, also let me know when you get them in
« Reply #9 on: March 07, 2010, 10:40:34 am »
I will check the arrival date.  BTW, if it is on Goodmarks website I can get it.  No matter what year models Ford Dodge Chevy.
If you email me what part number you are looking for I can get it.
Same goes for every Vendor listed on this page:
http://forum.73-87chevytrucks.com/smforum/index.php?topic=10531.0
Offline Tater502
« Reply #10 on: March 10, 2010, 02:57:51 pm »
Heres the pics.
From this...
To this...
Few washers
Andy
« Reply #11 on: March 10, 2010, 04:00:28 pm »
That's still up too high. The other thing you have to be very careful about is the fact that you don't have the support. These hoods are notorious for bending in half if they aren't properly supported. 123pugsy redid his hinges and posted about it I believe.
« Reply #12 on: March 10, 2010, 05:33:20 pm »
X2 on bending the hood. I have braces and it still is slightly bent. Make sure you lube the hinges very well. I did and it made a world of difference. Now I dont have to worry about bending the hood when closing it.
« Reply #13 on: March 10, 2010, 06:02:01 pm »
Offline Tater502
« Reply #14 on: March 10, 2010, 06:37:30 pm »
Yeah its still too high, but looks a lot better. I took the hinges off and cleaned and lubed them, the hood is easy to close.
If my hood is already a little bent will those supports straighten it back out? Is there any pictures of those supports so I can see what they look like and where they go?
Andy
