Author Topic: Striker bolt plastic sleeves?  (Read 14802 times)
Offline ron350
« on: February 26, 2010, 11:58:09 am »
Does any one have a part number for the Striker bolt plastic sleeves?
I have heard they are available at the dealership and the parts stores but have never seen a part number for any.
1975 C10 step side stock with 350 two bbl. & 350 trans.
Re: Striker bolt plastic sleeves?
« Reply #1 on: February 26, 2010, 12:01:17 pm »
I usually get them at the HELP! section of the parts store.
Offline ron350
« Reply #2 on: February 26, 2010, 12:55:17 pm »
Quote
OK but what is the part number all I can find are the short Ford sleeves.
Wish i had some made from brass.
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #4 on: February 26, 2010, 02:33:00 pm »
If your stock strikers are like mine you'll need the whole striker bolt.  I tried to get the bolt out of the washer before and ruined the bolt threads.  and you have to get the bolt out of the washer to slide the sleeve on it.
the whole striker bolt is Dorman# 38420.  never ever had luck with just the sleeves
Offline Mr Diesel
  • Aaron
« Reply #5 on: February 26, 2010, 04:23:02 pm »
I just bought the Ford ones and put them on. I think I had to trim them shorter though.
1976 C20 Crewcab, 6.2L/SM465
1983 C30, 6.2L/TH400
1983 K30 Crewcab 454/700R4
Offline Burban
« Reply #6 on: April 04, 2010, 12:06:40 am »
Easy alternative Fix. Go to Home Depot or Lowes Plumbing Department.  Buy a piece of PEX 1/2" flexible hose. (It looks like teflon white) Cut off a piece of the tube the length of the striker area ---about 3/4".  Slit it with a razor and slide it over your worn out striker.  Worked great for me and did not have to remove anything.  Total cost is about $1.25 .
« Reply #7 on: April 04, 2010, 09:47:51 am »
Being that new strikers are $5 bucks a piece I would just opt for new ones.
Offline Burban
« Reply #8 on: April 06, 2010, 10:40:23 pm »
The price is not the issue. Its the installation time and the very good odds of dropping and loosing the the nut and washer between the body panel when installing a new striker. (at least on a Suburban).
Offline ron350
« Reply #9 on: April 12, 2010, 11:45:37 am »
 Burbon thank you for the PEX trick it works great.
Picked up a 5 foot stick of ½ pex from Lowes for $1.25 but this stuff looks and cuts like hard nylon which is what i was looking for. :D
« Last Edit: April 12, 2010, 11:48:12 am by ron350 »
Offline eventhorizon66
« Reply #10 on: April 12, 2010, 04:18:05 pm »
I've gotta try this.
'85 C10 SWB 350 700R4 TKO600
Offline ron350
« Reply #11 on: April 12, 2010, 06:00:15 pm »
The ½ PEX is not a perfect fit but it is close enough to stop the rattle and let the doors close properly.
In the picture you can see there is a gap in the ½ PEX when on the striker bolt.
