Author Topic: Gas tank options  (Read 24249 times)
Offline 9d6ss
Gas tank options
« on: March 03, 2010, 08:28:35 am »
I've seen the blazer swap, any other suggestions?
Offline ccz145a
Re: Gas tank options
« Reply #1 on: March 03, 2010, 10:46:03 am »
There are plastic tanks available to fit right where the old ones fit.
Offline bigblock73
  • Yeller
« Reply #2 on: March 03, 2010, 12:29:07 pm »
Jeff
'73 swb 2wd
73-87.com
Offline 9d6ss
« Reply #3 on: March 03, 2010, 11:05:33 pm »
Thanks guys ;) Bigblock, what was ur total on everything? If u don't mind me asking?
Offline chadlovelady
« Reply #4 on: March 04, 2010, 04:14:38 pm »
Nice fuel door,,,would you be willing to sell me one of them machined pieces?
1985 GMC 4x4 3/4 ton
496 Stroker
Offline 82gmc3/4ton
« Reply #5 on: March 07, 2010, 07:44:16 am »
I went with a fuel cell after seeing Jeff's write up. I gotta say it looks bad ass! I still have the bed off so when people come over I get a lot of compliments.
Offline HAULIN IT
« Reply #6 on: March 07, 2010, 09:01:54 am »
Here is a couple pic's of my cell install, not the clean/detailed version of Jeff's (I've allways liked it, NICE Job!) but functionable. I moved the spare tire brace forward for the front crossmember. Lorne
Offline CreativeNotice
« Reply #7 on: March 07, 2010, 10:00:51 am »
So what is the benefit of a fuel cell over a regular tank? And isn't it a pain to fill up at the pump?
Offline Grover 1
« Reply #8 on: March 07, 2010, 12:13:43 pm »
The one thing i dislike about our trucks is putting gas in them.   Slow filling, you have to hold the lever or go on the slowest speed possible.  I feel pretty good if I can get a couple of bucks in before it shuts off.  That is why i moved my filler to the fender well in the bed.  Also, GM should have learned from F**d and put both fillers on the same side!!
1978 C-10 SWB
1986 K-10 SWB
1975 C-10 SWB
And here I sit so patiently
You have to pay to get out of
Offline HAULIN IT
« Reply #9 on: March 07, 2010, 04:48:51 pm »
For me, the biggest reason was the weight was now moved behind the rear axle to improve traction. The way the cell is made (sump in the rear, lower area, the gas HAS to get to the pump under launch. Mine was under under/right behind the driver, the pass. side will have still been bad, but not as bad as where it was. Originally I had trouble with the gas all going toward to back of the long tank away from the pickup tube on the launch, a longer tube toward the rear area fixed the stumble (from the fuel not getting to the carb), but I ended up moving it anyway for the weight placement.
 As for being a pain, not really much different than before...One benefit is that I can be on either side (not having to turn around) & still pump gas. Lorne
