Author Topic: Engine Noise  (Read 4365 times)
Offline 86CHEVYC10
Engine Noise
« on: March 11, 2010, 08:56:39 pm »
Hey I'm new this forum. I'm wondering if someone can help me with this noise i get when i drive my 86 Chevy with a sbc 350 in it. I had put aluminum heads on and new rockers. I got it all back together and started it up it runs fine. then once i go down the road like a mile or so, i start to hear like a ticking noise comming from the passenger side of the motor. I thought it was a miss adjusted rocker. so i re set all the valve lash on all of them. let it cool down same thing happens. can it possibly be a lifter? Thanks
86 Chevy C-10 350
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: Engine Noise
« Reply #1 on: March 11, 2010, 10:00:39 pm »
answer: yes.  It possibly could be a collapsed lifter.  Were the valves way out of adjustment when you adjusted them?
Re: Engine Noise
« Reply #2 on: March 11, 2010, 10:01:49 pm »
How did you adjust the valves? No bent pushrods? Get a mechanic's stethoscope and pinpoint where it's coming from.
Offline 86CHEVYC10
Re: Engine Noise
« Reply #3 on: March 11, 2010, 10:28:23 pm »
no the valves were in adjustment but i went back over them again just to make sure. i had went onto shopkey and got the sequence and did it to where the rocker touched the pushrod with spinning it then 3/4 turn. i had checked it with the stethoscope it is sounds like it is coming from cylinder 6. cam, lifters and pushrods have about 400 miles on them. before i put the new heads on.
86 Chevy C-10 350
Offline Josh454
Re: Engine Noise
« Reply #4 on: March 13, 2010, 08:20:22 am »
Sounds like you may be losing a lobe on the cam.  Check your lift on #6 and compare it to another cylinder.
Offline k5blazerfan
  • K5 blazers will never die
Re: Engine Noise
« Reply #5 on: March 13, 2010, 01:23:21 pm »
do the heads have pressed in studs? i had this problem on a 305 were the stud had come loose
Don't forget the tow chain!!! Might have to tow a ford home! :)
