Author Topic: Floor pans?  (Read 4499 times)
Offline SeanD
Floor pans?
« on: March 15, 2010, 06:51:43 am »
Has anyone ever done a write-up on replacing the cab corners, floorpans and rockers?  In most guys' builds it goes from before to after, but I'm interested in what and where things get welded together.
I just got an 80 step, and its got issues with all that plus the firewall.
Thanks!
Offline Jesse Walter
Re: Floor pans?
« Reply #1 on: March 15, 2010, 08:41:57 am »
Just do a search here.  There are plenty of threads with lots of pictures of floor, rocker and cab corner repairs.
Jesse Walter
86 K20 4x4
86 C30 Dump
Re: Floor pans?
« Reply #2 on: March 15, 2010, 12:50:57 pm »
Agreed, just remember to mock everything up with the door aligned in place and the door seal installed. Make sure all of your panel gaps are correct before you weld or bond any of the components in place. Most people tack, pin, or screw them in place first. Be careful if you're welding as not to overheat the metal and either distort it or burn through.
Re: Floor pans?
« Reply #3 on: March 15, 2010, 04:03:33 pm »
the 5 piece repair kit in the catalog has a direct link to a members install.
http://forum.73-87chevytrucks.com/smforum/index.php?topic=5661.0
Offline liftedchevys87
Re: Floor pans?
« Reply #4 on: March 31, 2010, 08:30:06 pm »
Do you still need help with this?
- 87 1/2 ton 350 4x4
- 78 1/2 ton 454 flat bed 2wd
