Author Topic: 1989 K5 Blazer project  (Read 285455 times)
Re: 1989 K5 Blazer project
« Reply #90 on: October 06, 2018, 10:23:09 am »
Nice. Should be a pretty slick setup!
I hope so.  I am happy to just get it going..
« Reply #91 on: October 17, 2018, 10:26:25 am »
Monday, October 15th, 2018: FlatOut Engineering Front 67-72 Kit and rear 55-59 Kit showed up today along with Aldan Coilovers.  Got it unboxed and checked off the items seems as though everything is here.
Since the front is weld in, I had to get the 5.3L/4L60E out along with the Porterbuilt front crossmember.  Did this alone so it took a little while longer but I disassembled the crossmember out from under the engine/trans and pulled it out and got it on the floor.
« Reply #92 on: October 17, 2018, 10:31:37 am »
Tuesday, October 16th, 2018: Started cleaning off the front frame rails So I can make some cardboard templates for boxing the inside frame rails since the outside frame rail will have to be notched and welded.
Wednesday, October 17th, 2018: Trying to make templates before I have to go and pick up my daughter from School..
« Reply #93 on: October 26, 2018, 06:45:15 pm »
Saturday, October 20th, 2018: Found some Corvette Z06 18x9.5" rims with tires (that will hold air) for mockup for $300.
Did some measuring to find the centerline of the spindle to mark the outside frame rail where it has to be cut.  The hashed portion is what I currently have to remove which will definitely require boxing plates.  I am going to mount the fender on and position the wheel in the center of the opening and do a remeasure on it.
Made templates for the boxing of the frame, there will be a C notch in front of the blue tape (actual the center will be at the end of the tape) I hope to have these cut next week.  I have a an email out to FlatOut Engineering on if this is enough as they recommend going closer to the firewall.  I still need to sort out access to the inner rail for access.
Drivers Side:
Passenger Side:
Although not bolted together all the way this is the difference in the PBFab vs FlatOut Engineering crossmembers.
« Reply #94 on: March 31, 2025, 05:42:43 pm »
Although nothing has been updated on this project it did have progress but I refused to post it.  Work was done, it didnt work and I was frustrated from about 2019-2022.
In July 2022 I dropped the Blazer off at a Chassis Shop.
Friday, September 6th, 2024: I got updated that work was being done with pictures on a frame table.
Friday, November 7th, 2024: I got notification that is was being Test fit with the body.
« Reply #95 on: March 31, 2025, 05:51:50 pm »
Friday, November 15th, 2024: I received this shot of the completed Chassis.
Friday, November 22nd, 2024: I received this shot of the completed Chassis.
« Reply #96 on: March 31, 2025, 05:55:15 pm »
Tuesday, November 26th, 2024: Went and picked up the Old C4 Chassis and the new body on the New Chassis and tucked it away in my Garage after spending the weekend rearranging for space.
« Reply #97 on: March 31, 2025, 06:06:14 pm »
Monday, December 30th, 2024: Ordered Wilwood front/rear brakes and a 3.55 geared 3rd member, which catches us up to today.
Fresh off the GM Tailgate Tour, I am hoping to get this at least in the driving dependable state for GM Tailgate Tour 2026.
Offline JohnnyPopper
  • Old Goof
« Reply #98 on: April 02, 2025, 03:58:43 pm »
WOW Stunning!!!
Did you clear coat the chassis?
With all that reinforcement, what type of beast will be in the heart?
1980 C-10 under construction
« Reply #99 on: April 02, 2025, 04:25:33 pm »
Sadly it is raw metal and I need to paint it or powder coat it.
It will probably be a Supercharged LS of sorts.
  • Old Goof
« Reply #100 on: April 03, 2025, 05:22:42 pm »
This stuff works great.
