Author Topic: custom instument panel  (Read 19212 times)
Offline Frozone
    • Gooische oldtimer vereniging
« on: March 24, 2010, 05:35:03 am »
Hi Guys,
I want to build a custom instrument cluster for my truck, therefore I'm looking for inspiration.
I'm thinking about something not so different from the stock cluster. I will be using stainless steel sheet metal.
A while ago I came upon some images of a truck with a diamond plate cluster but forgot to save them to my computer, anyone knows where I can find them? Tried searching for them here but could not find them.
Pics of similar instrument clusters are fine too.
Thanks in advance
Re: custom instument panel
« Reply #1 on: March 24, 2010, 11:53:02 am »
look at Flamingbig10's post in members rides:
« Last Edit: March 25, 2010, 01:34:43 pm by VileZambonie »
Offline Frozone
« Reply #2 on: March 25, 2010, 06:03:13 am »
That's the truck I saw before! Thanks!
Already thought about mounting them in an angle. I was thinking of buying some steel tube with the correct diameter and then cutting them of in an angle of about 15 degrees and recess the gauges in the tube. Kinda the same idea as the original bezel.
I'm also planning on making the indicator lights in the shape of an arrow and the warning lights of mini led's
Will be a lot of work but I think it will look cool in the end.
« Reply #3 on: March 25, 2010, 04:28:44 pm »
Why not just mount them in the factory location?
Offline Frozone
« Reply #4 on: March 25, 2010, 05:04:03 pm »
I bought a smaller diameter gauges so the holes in the original cluster are to big. Plus I like the challange of building my own. I will try to relocate the radio as well.
So why do it the easy way if there is a hard way?
« Last Edit: March 27, 2010, 06:20:53 am by Frozone »
Offline Gregzz4
« Reply #5 on: March 26, 2010, 11:07:25 pm »
Frozone, I am trying to upload or link a Pic for you of my Gauges
I used ABS, but it will give you an idea what will work for you in the stock location and the angle works well if you cut and recess it as I did
I eliminated the shift indicator for ease of install
The 4 lights I installed are; left and right turn indicator, hi-beam and brake warn from the distributor block
Good luck with your project !
« Last Edit: March 31, 2010, 05:27:55 am by VileZambonie »
'78 1/2 Ton
GMPP ZZ4 Q-Jet
700R4 Race Internals
3:42 Eaton
« Reply #6 on: March 27, 2010, 01:50:09 am »
capt what happend to my post above? i posted right after your first post it was there now its gone
Offline nucknoel89
  • Proud to be Canadian!
« Reply #7 on: March 27, 2010, 02:53:21 am »
I'm hoping to do a different cluster as well, though I wanna do the (99-07?) cluster.  Anyone know if I can relocate the heater controls lower or whatever and still make them function?
« Reply #8 on: March 27, 2010, 09:19:24 am »
I think when I tried to fix the post it vanished. Sorry about that
Offline Frozone
« Reply #9 on: March 27, 2010, 09:38:17 am »
gregzz4,
Your dash looks clean to. it's making me doubt about the way i'm going the make mine.  I like the way the gauges are flat with the panel, i like the look of the rings.
Offline Flamingbig10
« Reply #10 on: March 27, 2010, 09:24:22 pm »
« Reply #11 on: March 28, 2010, 03:02:54 am »
lol ok vile thought I screwed up by saying crouch but never got a email saying it was deleted.
greggs call me tim but to answer your question that aint your dash in those pics its mine ;-)
 Use the img code on photo bucket looks like this
 [îmg]http://i749.photobucket.com/albums/xx136/Gregzz4/Truck%20pics/2Newleft.jpg[/îmg]
« Last Edit: March 28, 2010, 03:04:32 am by Irish_Alley »
Offline Gregzz4
« Reply #12 on: March 28, 2010, 06:31:32 pm »
OK, now I really think I have my stuff together
I'm going to post my pics here, clean up my other posts and delete the Photobucket stuff
I need Photobucket for other things
'78 1/2 Ton
GMPP ZZ4 Q-Jet
3:42 Eaton
« Reply #13 on: March 29, 2010, 12:42:44 am »
flaming did you redo yours?
« Reply #14 on: March 29, 2010, 07:31:35 pm »
yes I've redone it 3 times since the diamond plate 2 stock locations and one custom I like the custom layout the best it easier to read all of the gauges
