Engine dies on the corner
Topic: Engine dies on the corner (Read 10827 times)
kilam68
April 03, 2010, 09:49:05 pm »
I have a 1980 2wd Jimmy. 350/350. The engine will idle all day long but when I put it in drive or neutral and step on the gas, it dies. E can only get to the end of by street. then it dies. I wait a little while and it starts back up. I have changeed the fuel pump, fuel filter, distributor, and coil. Any suggestions?
Thanks
1984gmchighserria
Re: Engine dies on the corner
April 04, 2010, 02:22:56 am »
check your vacuum lines
Lt.Del
Andy aka:SgtDel
DelbridgePhotography.com
April 04, 2010, 09:15:39 am »
next time it dies, check for spark right away. It'll limit a lot of stuff...fuel, vs. ignition.
do you smell fuel when it cuts off and you immediatley try to turn it back on?
www.DelbridgePhotography.com
www.HikerMania.com
www.delbridge.net/suburban
pontgta
April 04, 2010, 02:57:39 pm »
Could be dirty carb? Would need further info.. Does it do this all the time?
kilam68
April 04, 2010, 04:43:04 pm »
Happens all of the time. Somtimes I have to pump the throtle allot while turning the key to get it started. Then it dies again shortly thereafter.
youngblood222
April 05, 2010, 11:14:03 am »
cheack your timeing sounds like to me that you jumped a tooth on your timeing chain this happend to me a few years ago it would start and idle put it in gear it will run tell u give it gas and it will die
74 432cid small block
kilam68
April 07, 2010, 08:45:42 am »
Signs point to jumping a gear tooth. How do I fix it?
Lt.Del
Andy aka:SgtDel
April 07, 2010, 09:35:59 am »
check your timing to be sure...do you have a timing light?
if confirmed, you'll need a new timing chain. you can fix it w/ the engine in the truck, but, you'll have to remove the radiator, water pump and the like to get to the timing cover. Remove that and you see the two gears that the chain wraps around, one for the crank, the other for the cam. At TDC there is a dot on both gears next to a tooth on each signifying the gears are meshed correctly. If those dots aren't lined up, it jumped and a new chain is in order because the old chain has too much slack.
www.HikerMania.com
kilam68
April 11, 2010, 08:17:03 am »
Yes I have a timing light. Can I check to see if I'm a tooth off with it?
Lt.Del
Andy aka:SgtDel
April 11, 2010, 11:28:40 am »
it'll tell ya if your timing is off. If the distributor hold down bolt is tight, the timing should be knocked off any unless the belt jumped.
www.HikerMania.com
kilam68
May 11, 2010, 08:11:04 am »
Well I just found time to check the timing chain last weekend to no avail. The timing chain was not off. I have a buddy rebuilding my carburetor and I will see what happens then. Any other suggestions you might have would be great.
DnStClr
May 11, 2010, 04:37:22 pm »
Hopefully the rebuilt carb will fix it. With a new gasket you will eliminate the possibility of a vacuum leak under the carb too. Make a good check of all your vacuum lines like
1984gmchighserria
said.
Don
87 Chevy Silverado
ohio hab
1984 C-10, 383 SBC
May 11, 2010, 06:37:19 pm »
Could be a weak fuel pump, or obstruction or dirty sock on the pickup in the fuel tank. Sounds to me under a load, not ideling, running out of gas. Ken
jeff0547
June 03, 2010, 09:07:38 am »
I agree with
ohio hab
, my van does the same thing when the fuel tank is less than 1/4 full. I think that the line into the tank may have deteriorated. My solution is to keep more fuel in the tank. Hope this helps.
June 03, 2010, 03:06:24 pm »
Kinked fuel line would cause your problem.
