Author Topic: Best ring and pinon  (Read 4685 times)
Offline slimpickens8
Best ring and pinon
« on: April 06, 2010, 08:52:17 pm »
Wheres the most reasonable place to get ring and pinon gears????? Not sure if i have to yet gotta take the case off and see......  :(
Re: Best ring and pinon
« Reply #1 on: April 06, 2010, 10:21:31 pm »
Why do you think you need a ring and pinion?
http://www.ringpinion.com/
Offline fitz
« Reply #2 on: April 06, 2010, 10:36:09 pm »
I've yet to break a GM ring and pinion ( I've broke a few spider gears on a 10 bolts).
My 81 stepside runs a 14 bolt SF with Yukon gears and an Eaton posi in it, so far it's been great.
Offline treestandjunkie
« Reply #3 on: April 07, 2010, 03:59:41 pm »
I use Randy's ring and pinion.
« Reply #4 on: April 08, 2010, 09:07:55 am »
Im not sure yet. I hear popping when i back up my neighbor said it sounded like it was in the brake drum, Its raining so ive yet to break into it.
Offline SUX2BU99
« Reply #5 on: April 08, 2010, 02:10:17 pm »
Check the operation of the emergency brake adjuster and everything else in both drums. Lube the friction points (not the shoes obviously lol) while you are at it.
