Best ring and pinon
Topic: Best ring and pinon (Read 4682 times)
slimpickens8
Best ring and pinon
April 06, 2010, 08:52:17 pm »
Wheres the most reasonable place to get ring and pinon gears?
? Not sure if i have to yet gotta take the case off and see......
Re: Best ring and pinon
April 06, 2010, 10:21:31 pm »
Why do you think you need a ring and pinion?
http://www.ringpinion.com/
fitz
April 06, 2010, 10:36:09 pm »
I've yet to break a GM ring and pinion ( I've broke a few spider gears on a 10 bolts).
My 81 stepside runs a 14 bolt SF with Yukon gears and an Eaton posi in it, so far it's been great.
treestandjunkie
April 07, 2010, 03:59:41 pm »
I use Randy's ring and pinion.
slimpickens8
April 08, 2010, 09:07:55 am »
Im not sure yet. I hear popping when i back up my neighbor said it sounded like it was in the brake drum, Its raining so ive yet to break into it.
SUX2BU99
April 08, 2010, 02:10:17 pm »
Check the operation of the emergency brake adjuster and everything else in both drums. Lube the friction points (not the shoes obviously lol) while you are at it.
Best ring and pinon
