Author Topic: Steering gear box rebuild  (Read 27294 times)
« on: April 28, 2010, 10:35:09 pm »
Im looking to rebuild my steering gear box, as that is where the play is. I browsed a parts store online, and they ask what casting number I have. Anyone know where it is located so I can find it faster? Anyone rebuild one? How was it?
« Last Edit: May 08, 2010, 12:02:04 am by beastie_3 »
Offline Jacked85K10
Re: Steering gear box rebuild
« Reply #1 on: May 10, 2010, 12:03:09 am »
Easy rebuild if you know what you're doing. The casting number is at the mounting flange where it bolts to the frame. You will have to remove the box to see it.
« Reply #2 on: May 10, 2010, 01:49:07 pm »
OK thanks. Thats what I didnt want to know. I was hoping it was visible prior to removing it. Either way, I suppose I have to get it done. Thanks!
« Reply #3 on: May 17, 2010, 07:42:15 pm »
Is there anyway to predetermine what casting number is on the steering gear box? Im looking for a rebuild kit, and it lists two numbers. First design 7802644L or second design 7802644.
« Reply #4 on: May 17, 2010, 07:43:54 pm »
You're going to wish you just got a reman unit. They're cheap enough.
« Reply #5 on: May 17, 2010, 09:55:33 pm »
Really that hard to rebuild huh? With the casting numbers, I assume they have to match if I get a new one?
Offline jaredts
« Reply #6 on: May 18, 2010, 02:39:24 pm »
Just asking:  Are you sure its the steering box causing all of the play?  A brand new unit is going to have some slop in it too--I've seen a lot of people say these are bad when they really aren't.  What looks like minor movement in other parts can add up big time.  Is this a 2 or 4 wheel drive?
« Reply #7 on: May 18, 2010, 02:45:40 pm »
4wd. It's the only thing left I haven't replaced. The steering wheel and steering shaft has slop in each direction before the pitman arm turns. How much slop does a new unit have?
« Reply #8 on: May 18, 2010, 04:02:01 pm »
You're sure the play isn't in the rag joint right? Do you know how to do the high point lash adjustment?
« Reply #9 on: May 18, 2010, 04:41:31 pm »
I'll double check to make sure it isn't the rag joint. Is the high point lash adjustment in a manual? I have haynes, chilton, and the factory manual.
Offline joesgarage71
  • Wrench
« Reply #10 on: May 18, 2010, 07:16:02 pm »
 Yea! X2 you start messin with them steel balls LOL
« Reply #11 on: May 18, 2010, 08:50:26 pm »
« Reply #12 on: May 19, 2010, 02:07:56 am »
Thanks for the link! Ill try to get to it this weekend and report back.
« Reply #13 on: May 30, 2010, 12:15:34 am »
Finally got a chance to look at my slop a little closer. The steering shaft turns almost 1/4 turn before the pitman arm starts to move. The rag joint isnt the issue, its all firm. I'll probably order a new box after I decide which frame brace kit I want to get.
« Reply #14 on: May 30, 2010, 05:37:23 am »
Try adjusting the lash first just don't over do it.
