Author Topic: Correct pinion angle for a flipped rear?  (Read 5819 times)
Offline 82ChebySWB
« on: May 02, 2010, 09:34:40 am »
Good morning, Does anyone know what the correct pinion angle needs to be for an '82 SWB with a flipped rear?  I've got a custom 4" built all aluminum drive shaft that I'll be running...and I want top make sure that nothing is in a bind at all.
THANKS,
Brian
Brian
'82 Chevy Silverado AKA Project "Cheby"
Offline 82ChebySWB
Re: Correct pinion angle for a flipped rear?
« Reply #2 on: May 03, 2010, 06:30:07 am »
Yes, the rear was flipped using two "off brand" Ebay Special U shaped brackets.
The motor will be solid mounted....and a Poly trans mount (since the first link you posted suggested that mounting points made a difference in rearend movement)
Brian
« Reply #3 on: May 03, 2010, 10:20:12 am »
you want to be about 3 or 4 degrees.
Offline 82ChebySWB
« Reply #4 on: May 03, 2010, 11:46:58 am »
Thank you sir!!!  ;D
Brian
