General Discussion
Headlight restore
Topic: Headlight restore (Read 4788 times)
beastie_3
Josh
Headlight restore
June 06, 2010, 07:17:39 pm »
Finally got around to cleaning up my headlights. Thought I would share and possibly encourage anyone to get it done. I used 1500 and then 2000 grit wet sandpaper and then finished up with Meguiar's PlastX. They have a kit, but it was cheaper to buy just the bottle, sandpaper and foam pad separately. I do wish that I had bought the rotary pad though...
Before
After
Semper Fi
Re: Headlight restore
June 06, 2010, 09:05:33 pm »
I use the 3M kits and they work mint
⌠ŻŻŻŻŻ' [☼===☼]
Blazin
Blazin new trails!
June 06, 2010, 09:37:04 pm »
Did this to a 46 foot diesel pusher motor home last week. Some mouth breather had painted the front of it, then peeled the tape off and clear coated over the head lights. DOH
So I sanded them with 400 dry first, then 600, then, 800, then 1200, then 1500 wet. Then I used 3Ms headlight compound. it did OK. Then I used 3M micro finishing compound. That worked allot better.
beastie_3
Josh
June 06, 2010, 11:07:29 pm »
I saw the 3M kit, was thinking about getting it. Turned out good enough for the mean time. End of summer I'll probably do it again.
Semper Fi
Blazin
Blazin new trails!
June 07, 2010, 06:26:32 am »
Snap on makes a nice kit with a air tool, wheels, and all the crap to go with it. Like $130.00
beastie_3
Josh
June 07, 2010, 12:16:57 pm »
Wow thats crazy.
Semper Fi
June 07, 2010, 04:57:55 pm »
The 3M kit is like $15-$20bucks and goes in your drill.
http://www.midwayautosupply.com/showproduct.aspx?productid=108247&affiliateid=10050
⌠ŻŻŻŻŻ' [☼===☼]
Blazin
Blazin new trails!
June 07, 2010, 10:14:04 pm »
Thats the kit I got and it sucked.
June 07, 2010, 11:26:01 pm »
I use them all the time and they come out mint.
⌠ŻŻŻŻŻ' [☼===☼]
Blazin
Blazin new trails!
June 08, 2010, 06:04:31 pm »
I ended up using my 3' DA with the grits I mentioned above. Then I tried buffing them with the pad from the kit and the juice they send. The Micro Finishing compound worked way better.
General Discussion
Headlight restore
