General Discussion
Name that jingle!!
Topic: Name that jingle!! (Read 10907 times)
Re: Name that jingle!!
Reply #15 on:
June 14, 2010, 02:05:02 am »
how did you check the suspension before?
Grim 82
Reply #16 on:
June 14, 2010, 10:45:48 am »
Make sure your e-brake cable isn't knocking against your exhaust, and check your hangers/connections. Check that your fan isn't hitting the shroud when you hit bumps, and check the rubber mounts that secure your radiator from bouncing around.
1981 ss chevy
Reply #17 on:
June 14, 2010, 09:20:32 pm »
bought new shocks for the front, cuz i needed new ones anyway and that solved the problem works for me!!
Grim 82
Reply #18 on:
June 15, 2010, 03:28:12 pm »
Glad you got it figured out.
beastie_3
Josh
Reply #19 on:
June 15, 2010, 06:34:32 pm »
Did you inspect the shocks after you took them off to see if a seal was bad or maybe the bolts were loose?
Semper Fi
1981 ss chevy
Reply #20 on:
June 18, 2010, 11:48:12 am »
seals were trashed in them
beastie_3
Josh
Reply #21 on:
June 18, 2010, 12:17:10 pm »
Ya that might do it.
Semper Fi
Reply #22 on:
June 18, 2010, 06:22:02 pm »
Sounds like you're describing pinging to me.
General Discussion
Name that jingle!!
