Author Topic: starters and flywheels  (Read 7481 times)
Offline 77 cc lb
« on: June 10, 2010, 08:54:22 am »
this might be a dumb question but i am baffled. i thought i had my starter prob. fixed (meshed fine, no grinding), but i go out a couple days later to try and start and i get the grinding noise again. it's a 292-6. is it poss. there are diff. starter and flywheel combinations for this engine? difference between a car 292 and a truck 292? thanks for any advice.
87 Chevy crewcab shortbed soon to have a 454/400
Re: starters and flywheels
« Reply #1 on: June 10, 2010, 11:59:15 am »
Make sure your starter didnt come loose.
Offline 77 cc lb
« Reply #2 on: June 10, 2010, 01:33:45 pm »
it's not loose. i even put in 1/8in. worth of shims and it still doesn't mesh. is it poss. there are different gears on starter, that's why it won't mesh
« Reply #3 on: June 10, 2010, 04:40:59 pm »
« Reply #4 on: June 10, 2010, 08:37:39 pm »
That diagram should go in the tech section!
« Reply #5 on: June 11, 2010, 05:30:59 am »
I emailed them to Chris a few days ago. I'm sure he'll put them in there.
« Reply #6 on: June 11, 2010, 03:46:42 pm »
I am going to put them there.  I have been tied up in the evenings getting a 3800 pulled out of a Grand Prix...
Offline TexasRed
« Reply #7 on: June 11, 2010, 05:12:24 pm »
No sawzall or torch?
Offline 77 cc lb
« Reply #8 on: June 11, 2010, 06:14:20 pm »
i'm just going to suck it up and put on a new flywheel. should have done that in first place. thanks for info vilezambonie
« Reply #9 on: June 11, 2010, 06:30:49 pm »
If the flywheel is ok replacing it won't help.
Offline 77 cc lb
« Reply #10 on: June 11, 2010, 07:51:31 pm »
there aren't any teeth missing but it is starting to wear down from trying to start it. should i keep shimming? could a starter from a sbc or a bbc work on this engine?  i think my problem is not having the right starter.
« Reply #11 on: June 12, 2010, 12:12:01 am »
there is a difference in the car and pu starters as far as a sb or bb no they wont work i would fork over 40 bucks about to autozone and get one made for your truck start fresh
Offline 77 cc lb
« Reply #12 on: June 12, 2010, 11:26:57 am »
i did get  the recommended starter and it was grinding on me, got a smaller high torque and it started grinding on me. the p/o swapped out the 454 for this. so i don't know what the 292 came out of and if they swapped parts around.
« Reply #13 on: June 12, 2010, 07:49:21 pm »
The block numbers should tell you I. Think or about
