Author Topic: Connecting PRNDL? 1981 C10.  (Read 5784 times)
Offline Danielc409
« on: June 21, 2010, 07:01:28 pm »
Did a quick search and didn't find anything specifically related to connecting this. ( Sorry if I over looked )
Recently I replaced my steering column because my previous was punched and the housing was damaged.
Well when I was removing the old one, I didn't take notice how I disconnected the PRNDL. I have the other column in with no problems but couldn't figure out where to hook the cable to.
Here is the picture I took from another thread ( fitz post ) to show what it looks like:
It's installed and everything, I just don't know where to connect the end of the cable. I'm at work right now or else I could try to provide more pictures.
Re: Connecting PRNDL? 1981 C10.
« Reply #1 on: June 21, 2010, 07:15:15 pm »
Right on the column jacket. When you shift you'll notice the whole jacket roatates pulling on the cable.
Offline Danielc409
« Reply #2 on: June 21, 2010, 07:17:20 pm »
Just anywhere on there? I think why I didn't figure that out because I was shifting the level before it was installed, so the whole column was probably spinning.
Thanks a lot, I'll have a look at it tomorrow.
« Reply #3 on: June 21, 2010, 11:04:47 pm »
You may need to relocated it a couple times to get it where you like it.  But it needs some tension when sitting in park.
Offline Danielc409
« Reply #4 on: June 22, 2010, 02:35:32 pm »
Thanks for the replies folks, I got it setup today, works just fine now.
