Author Topic: 4x4 LWB DS length and interchange with a 2wd trans.?  (Read 3026 times)
Offline Swims350
    • Cars and trucks
« on: July 01, 2010, 03:36:18 pm »
First question, 4x4 driveshaft work with a 2wd trans.? Like would the yoke be the same? If not can it be changed to a 2wd yoke? I'd think so.
2nd what length is a long wheel base 4x4 driveshaft?
www.cardomain.com/id/benwa454
Re: 4x4 LWB DS length and interchange with a 2wd trans.?
« Reply #1 on: July 01, 2010, 03:53:43 pm »
Everything will change based on wheel base, GVRW, Trans, 4x or 2x, axles etc. Way too many variables.
Offline Swims350
    • Cars and trucks
« Reply #2 on: July 01, 2010, 03:58:39 pm »
good info to know, but to answer some it would be going behind a th350 short tail 77 model, and a 10 bolt rear end from an 84, 2wd short bed. But that's why I asked about a 4x4 long wheel base, long wheel base, ebing alot longer then I need, but 4x4 taking up alot of room for the transfer case, so maybe balance it out for me to be the right length. I wasn't sure if the output on the t-case was the same as a 2wd trans. or not.
