Author Topic: Engine knocking  (Read 5604 times)
Offline discot315
  • Trevor - 1980 Chevy K10
Engine knocking
« on: July 07, 2010, 09:14:14 pm »
So I got my truck running and insured about a week ago and on the weekend i was up a mountain 4x4ing with some buddys and my engine started knocking and smelled really bad and was burning oil. So i shut it down and let it sit for a bit and started it and it stopped so got back to my house and by then the noise was going again and it was loud and on the way home the truck randomly stalled on me. I checked the oil and it was really low so i added oil til it was full (4 liters) today and started it and it was fine then once it warmed up the loud knocking came back... Not really sure what it could be, my dad says it could be a crank baring and it doesnt sound like a valve because its a deep knocking and its way to loud. Sooooooooo........ ANY suggestions would help! Thanks!
ps sorry bout the long story lol
1980 K10- 9" lift with 38's. 350 4speed lwb
1976 / 85 front clip K20 - 4" lift with 33's. 350 4speed lwb
Re: Engine knocking
« Reply #1 on: July 07, 2010, 09:54:30 pm »
Are there metal fillings in the oil? Whats the oil pressure reading?
Offline discot315
Re: Engine knocking
« Reply #2 on: July 07, 2010, 10:04:23 pm »
Umm im not too sure about that, it didnt seam like it. and oil pressure was reading at first just under half on the guage but when the knocking got loud it was down to under a quarter on the guage. (i think its a quarter) around the first mark, sorta bouncing around there.
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: Engine knocking
« Reply #3 on: July 08, 2010, 12:19:30 am »
drop the oil pan and check out the oil pump and screen...ensure it isn't clogged and as Blazin said, check for shavings.
while the pan is off, check out the rod bearings and main bearings.  Put pressure on the rods and see if any play.
have someone turn the crank at the pulley w/ a 5/8 inch socket.  Watch in from down below.  Try to get a flashlight and check up at the pistons and all bearings.
after a good visual check of bearings and applying pressure and if no problems, put a new pump on it and button it back up and see if that solves the problem.
Offline discot315
Re: Engine knocking
« Reply #4 on: July 08, 2010, 12:35:30 am »
What would shavings in the oil mean??? Il try all that, il get the oil pan off and see what i can do from there. Is there any way of testing the oil pump?
Offline Lt.Del
  • Andy aka:SgtDel
    • www.delbridge.net
Re: Engine knocking
« Reply #5 on: July 08, 2010, 07:12:43 am »
oil pumps do go bad.  If you go through the trouble of dropping the pan with a noise like that and pressure readings like you explain, might as well put a new pump in.  They aren't expensive.
shavings are just pieces of metal which would indicate too much wear (metal on metal contact) inside the engine = not good.
Offline bgctrading
Re: Engine knocking
« Reply #6 on: July 08, 2010, 06:55:13 pm »
A deep knocking would indicate a problem sounds like a bearing issue.
Re: Engine knocking
« Reply #7 on: July 08, 2010, 07:11:31 pm »
Sounds like a rod knock
