Author Topic: 454 to 700r  (Read 17219 times)
Offline raelayotte
454 to 700r
« on: July 14, 2010, 12:25:17 pm »
Could someone help me find the right flywheel to put behide the bbc so i can use the 700r the 454 is out of a 93 1ton the tranny is out of a 91 k5
thanks
Offline raelayotte
Re: 454 to 700r
« Reply #1 on: July 15, 2010, 09:23:27 am »
can some help i need the the part number
Re: 454 to 700r
« Reply #2 on: July 15, 2010, 09:31:52 am »
Wouldn't that be the fly wheel out of the bbc?
Offline raelayotte
Re: 454 to 700r
« Reply #3 on: July 15, 2010, 09:37:20 am »
what bbc flywheel do i need to hook up to the 700r torque converter
Re: 454 to 700r
« Reply #4 on: July 15, 2010, 09:38:11 am »
The one that came off the 454
Offline raelayotte
Re: 454 to 700r
« Reply #5 on: July 15, 2010, 12:26:20 pm »
it's for a 4 wheel drive 91 700r. the 454 motor came out of a 93 1 ton dually with the 4L80e 2 wheel drive chevy. the torque converter from the 1 ton is bigger than the 700r from the k5, so the flywheel won't match up to the 700r.
can anyone help?
Re: 454 to 700r
« Reply #6 on: July 15, 2010, 02:19:33 pm »
There is a 10-3/4" and 11-1/2" converter bolt pattern, you have to know which one you need to get a part number. If the 700R4 converter is to small you need the smaller bolt pattern.
Re: 454 to 700r
« Reply #7 on: July 15, 2010, 04:57:46 pm »
X2
Offline raelayotte
Re: 454 to 700r
« Reply #8 on: July 16, 2010, 01:51:50 pm »
Offline raelayotte
Re: 454 to 700r
« Reply #9 on: July 18, 2010, 04:55:53 pm »
well the 2 bolt patterns will not work my converter is 9.5.
Offline raelayotte
im still lost
« Reply #10 on: July 18, 2010, 05:16:23 pm »
I have a 87 blazer 4x4 tring to put a 454 in . only thing is the flywheel and the converter will not match up the bolt pattern on the converter is 9.5 and the other is 10.75 and 11.5 i now what u all saying . i have 3 converters and there all 9.5. so i out looking for a converter with a 10.75 both pattern
Offline Swims350
    • Cars and trucks
Re: im still lost
« Reply #11 on: July 18, 2010, 06:50:38 pm »
ok let me try to figure this out, is the flywheel from the big block and the year of the big block? Is the torque converter from the big block or the stock motor?
I ask because the stocker would be a 1 piece rms and the big block may not be, aint sure, that could be the difference. That and some flywheels are dual drilled. does yours have 6 holes? if so did you try to rotate it to the next hole and try it?
Now another thing on some of the older trucks and cars at least small blocks, not sure on big block they have a 168 tooth flywheel and a 153, which would be smaller. Maybe if this is the case you need the small flywheel.
www.cardomain.com/id/benwa454
Re: im still lost
« Reply #12 on: July 18, 2010, 08:07:35 pm »
Just get a dual bolt pattern flexplate applicable to your engine
Re: 454 to 700r
« Reply #13 on: July 19, 2010, 12:23:32 am »
what i would do is go to autozone get what ever they have that seams to work and check it if its wrong just return it
Offline raelayotte
Re: im still lost
« Reply #14 on: July 19, 2010, 10:00:36 am »
a duel bolt is 11.5 and 10.75 my stock 700r converter bolt pattern is 9.5
