Author Topic: Finally got my first 86!  (Read 71070 times)
Offline 86gmc23
« on: July 16, 2010, 05:27:17 pm »
Bought it for $200 and shipped 80 miles for free =) Guy told be its a 1988 (vin1GTDC14N4GF) What do you guys think?
Offline 86gmc23
Re: Finally got my first 86!
« Reply #1 on: July 16, 2010, 05:28:13 pm »
What trans is this btw?
Offline oldwhity
« Reply #2 on: July 16, 2010, 05:39:52 pm »
Good deal! I'm not exactly sure which tranny's in it so I won't steer you wrong.
Rob G.
81 Chevy K20 4x4 LWB stepside
Offline 86gmc23
« Reply #3 on: July 16, 2010, 05:43:48 pm »
Do you know where the casting number for the block is by chance? Right now the heads are off it.
Offline oldwhity
« Reply #4 on: July 16, 2010, 05:49:55 pm »
On the block behind where the drivers side head would be. You'll see a ledge where the bellhousing bolts to. Clean the top of that off and you'll see the digits. Usually around 7 or 8 digits. I have a binder with numbers if you need reference. If it's a crate motor it may read "GM 5.7" or "GM 5.0.
Rob G.
Offline 86gmc23
« Reply #5 on: July 16, 2010, 06:10:50 pm »
It reads: GM 5.0L then a "G" I believe. Cant make out the G real good but I think thats what it is.
Offline 86gmc23
« Reply #6 on: July 16, 2010, 06:27:45 pm »
This is a crate motor you say?
Offline 86gmc23
« Reply #7 on: July 16, 2010, 06:38:44 pm »
Was looking around with these numbers and on www.nastyz28.com I got this(which doesn't make sense) :
V0910CHC
V=Flint
0910=Sep 10th
CHC=Suffix Code= 1975,76,80 350ci 210hp corvette motor.
But it says on the block GM 5.0L. Can anyone help me ID my motor, very confused now lol
Just found another site that says the same but also has a 307ci 115hp for the suffix CHC
« Last Edit: July 16, 2010, 06:41:24 pm by 86gmc23 »
Offline oldwhity
« Reply #8 on: July 16, 2010, 07:30:46 pm »
Some of the numbers I have printed out are from that same website. Another good site is mortec.com.
When I got my 85 Sierra, the guy told that the motor was replaced with a crate. When I checked the castings, it read GM 5.0(305cid). I sort of assumed that all crate motors carried that similar casting. When I pulled the motor out of my k30 a couple of days ago, it read GM 5.7(350cid). I automatically assumed it was a crate. Maybe someone will chime in with a little more insite to these castings. I wonder if the later years(mid to late 80's) came with these castings from factory. It still wouldn't explain your findings though.
Where did you find V0910CHC? Was it on the engine boss in front of where the passenger side head was?
Rob G.
Offline 86gmc23
« Reply #9 on: July 16, 2010, 07:33:57 pm »
What is the engine boss?
It was on the front of the motor on passenger side where head is yes.
Offline oldwhity
« Reply #10 on: July 16, 2010, 07:49:39 pm »
I call it a boss. It's that milled ledge where suffix codes are sometimes stamped behind the alternator.
Ok, according  to Mortec.com, our castings may not necessarily be crate motors. There should be a date code on the back near the casting or on the other side(passenger) of where the bellhousing bolts to.
Rob G.
Offline 86gmc23
« Reply #11 on: July 16, 2010, 08:05:49 pm »
I'll look tomorrow and post any findings, thanks for your help man
Offline oldwhity
« Reply #12 on: July 16, 2010, 08:20:20 pm »
Hey, no problem.
CHC=
Yr      CID      Trans                             VIN      hp      Carb Body
1973  307cid  turbo hydromatic,Calif NB2            115hp 2bbl  F,B, and X body vehicles
1975  350cid  m/t,h/p                           T L82   205hp 4bbl  Vette
1976  350cid  m/t,h/p                           X L82   210hp 4bbl  Vette
1980  350cid  Auto trans                       L                          Full size
None of these matches your casting. ???
BTW: this info came from nastyz28.com too.
Rob G.
Offline 86gmc23
« Reply #13 on: July 16, 2010, 09:49:11 pm »
Casting as in the "GM 5.0LG"? A 307ci is still a 5.0L (5.03083L). I dont know though, hopefully I'd find more info tomorrow
Offline Swims350
    • Cars and trucks
« Reply #14 on: July 16, 2010, 10:02:35 pm »
CHC 73 307 Nova 115 L-14 TH 350 2-Brl A.I.R.
CHC 73 307 Chevelle 115 L-14 TH 350 2-Brl A.I.R.
CHC 75 350 Corvette 210 L-82 4-spd 4-Brl
CHC 78 350 Camaro 170 LM-1 TH 350 4-Brl
CHC 80 350 Impala 190 LM-1 TH 350 4-Brl
CHC 88 305 Camaro 220 LB-9 700R 4-Brl
what about the heads? any casting numbers?
« Last Edit: July 16, 2010, 10:06:19 pm by Swims350 »
www.cardomain.com/id/benwa454
