Author Topic: 81 C10 a/c compressor - R4 unit Convert to A6 or not?  (Read 15027 times)
Offline Bluejake81C10
« on: July 20, 2010, 10:42:04 am »
Hello All,,, New guy here, looking for some help.
my quick intro:  2 yrs ago I bought this 81 C10 for a junk hauler for $2200.  I put zero money into it and a yr later it was still running great.  I figured it would be worth an engine rebuild and finally had it done.  Since that time about 6 months ago, I discoverd the huge demand and market for these trucks and I've been so impressed with this 30 yr old vehicle, I am now a hooked for life Chevy C10 fan.
I have 81 C10 Scottsdale w/ 5.7 2wd and R4 model a/c compressor.  a/c is squeeky, drags engine causing stalls, and is generally not useful.  From all I read R4 units are prone to problems.  I want to either convert to A6 model, or replace with a better manufactured R4 direct replacement unit.  Anybody with exp here, your feedback is greatly appreciated.  I'm handy but not exactly a Uber Mechanic man.  Thnx.
Re: 81 C10 a/c compressor - R4 unit Convert to A6 or not?
« Reply #1 on: July 23, 2010, 11:12:50 pm »
No replies so here's the answer to my own question after a few days of research.  Somebody may find this useful.
There is a company out of Tx call oldairproducts.com
Old air products has compressors, brackets, pulleys, & just about everything else need to fit or upgrade your a/c unit.  My old GM R4 compressor can be replaced with a new bracket & a Sanden 510 model compressor.  Compressor, Bracket, accumulator, and orifice tube for a little less than $400.
« Reply #2 on: July 24, 2010, 08:16:27 am »
There is nothing wrong with the R4. If it's squeaky the belt is probably loose or out of alignment or both. The AC is a big load on the engine and will drag the idle down. Is your idle speed solenoid connected?
Offline Franky
« Reply #3 on: September 24, 2010, 06:11:30 am »
I have installed at least 50 R4's that didn't come from MB on MB's & never have seen a premature failure!
Here is a good example of that MB crap! The A6 compressor from a MB dealer lists for $2,370!!!! I buy that exact compressor from a GM Delco supplier brand new for $305!! & that includes the clutch.Furnace Replacement Does MB really need to make $2,000 profit on a single compressor?????
« Last Edit: September 27, 2010, 02:52:52 am by Franky »
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #4 on: September 24, 2010, 07:17:37 am »
I wonder if they're hiring.  I'm in the wrong buisiness.   :o
Offline Grover 1
« Reply #5 on: September 24, 2010, 01:24:41 pm »
You can buy Sandens on Ebay, they're a good compressor.  You can also get a compressor from a newer GM truck, they are lighter, smaller and don't drag the engine as much.
1978 C-10 SWB
1986 K-10 SWB
1975 C-10 SWB
And here I sit so patiently
You have to pay to get out of
