Heart transplant coming soon!
Topic: Heart transplant coming soon! (Read 12608 times)
Blazin
Blazin new trails!
August 10, 2010, 08:38:10 pm »
Head gasket gave it up in the 86 this morning! Didn't quite make 227,000 miles!
BigHemi353
Diesel Enthusiast
Re: Heart transplant coming soon!
August 10, 2010, 08:52:04 pm »
Aww! Thats too bad! Im sure it had a good run though. lol
Blazin
Blazin new trails!
August 10, 2010, 09:22:11 pm »
Was a faithfull motor both times I have run the truck. It sat for about four years while I swapped the cab etc.
August 10, 2010, 09:27:49 pm »
Always a good reason for upgrades
TexasRed
August 10, 2010, 09:38:23 pm »
Might still be under warranty.
fitz
August 10, 2010, 10:13:10 pm »
Are you going to grab a spare 350 from 1 of your parts trucks?
Blazin
Blazin new trails!
August 10, 2010, 11:22:47 pm »
I have a low milage TBI 350 in one of them. Going to slide an RV cam, double roller chain, and a high volume pump into it. Need to get an intake to run a carb too.
jaredts
August 11, 2010, 11:52:37 am »
Are you going to leave the tbi heads on there?
fitz
August 11, 2010, 03:18:37 pm »
Does your TBI motor have the fuel pump boss on it?
Blazin
Blazin new trails!
August 11, 2010, 10:08:38 pm »
Yes I am leaving them, and it has a place for a fuel pump.
pocket5s
87 Chevy
August 12, 2010, 10:57:12 am »
I had a head gasket give out recently myself and after a replacement and a failed head I decided to pull the motor and build a 383.
Blazin
Blazin new trails!
October 24, 2010, 01:00:52 am »
After the head gasket gave it up I was still limping it along as I only live about 4 miles from work. Figuring I would get the motor done sometime before snow. Well the clutch blew lunch and its been sitting for about a month now. Been gathering parts. I had a guy that owed me money rebuild this motor about 15 years ago. After about 700 or 800 miles the harmonic balancer fell off and munched the end of the crank where the key way goes. Its been sitting under the hood of that truck ever since. Got run about once a year. I put a new key way in, and filled the missing metal on the crank with weld. Put new rear, and front main seals. New intake, valve cover, and one piece oil pan gasket. Then I primed the bare metal with Transtars self etching primer. I painted all the rust with Chassis Saver. Then I gave it a nice fresh coat of paint. Going to try and drop it in next weekend.
Catapilar yellow baby!
Last Edit: October 24, 2010, 01:10:38 am by Blazin
slammed79
Thou shalt not drive stock
October 24, 2010, 01:53:14 am »
As much as I am not a fan of yellow, Cat yellow makes my inner redneck heart go pitter-patter. Very nice!
Praise the lowered
78 Chevyrado
Z62 ON-ROAD
Site Supporters
October 24, 2010, 08:03:59 am »
Didn't you know Cat Yellow adds torque? Looks like it does anyway. I like it.
Blazin
Blazin new trails!
October 24, 2010, 08:18:19 am »
Ain't no 550 C15 but it will work!
