Body, Glass & Paint
Hood question
Topic: Hood question (Read 10258 times)
turbo1
Hood question
August 18, 2010, 11:41:29 pm »
The underside (or bottom ) of my hood needs some tlc. The support is separating from hood skin , I can see the old factory glue or seam sealer material has failed. The question is what should I use to bond the two back together
Thanks in advance Guys..
Da67goatman
Site Supporters
Burban
Re: Hood question
August 19, 2010, 09:35:41 am »
I would either weld it or steal some of my dads PL400 super adhesive and glue it back on.
<Pitcrew>
1992 fullsize Blazer 4x4 35s no lift, 4.10s, Hella driving lights, TJ Flares, Huge bumpers, Snorkel, custom interior
Re: Hood question
August 19, 2010, 11:02:02 am »
Wouldn't weld it for one I honk it needs to flex a little and the heat will burn off any paint on top
Bitzer!
Smiles per gallon
Re: Hood question
August 19, 2010, 02:42:56 pm »
I'd be interested to what you guys use as I will need to refit my slam panel to the rad core
1979 GMC CrewCab C20 1t
jaredts
Re: Hood question
August 19, 2010, 03:11:56 pm »
Panel bond adhesive? OEM hoods that I've seen use something similar. I don't think its seam sealer.
turbo1
Re: Hood question
August 19, 2010, 06:18:27 pm »
Yes... after talking my auto body supply guy, Panel bond adhesive is what they use..3M and others make it.Thanks for the replys guys.
HAULIN IT
Re: Hood question
August 19, 2010, 08:25:54 pm »
A urethane seam sealer/ adhesive is the right idea. Panel bond adhesive is for joining Two pieces of metal, however this is more for the edges where the panels fit up tight (like around the edges of a door skin, ect). It does not flex very much & can cause distortion during opening & closing, ect. & most likely will come loose from one half in short order for the same reasons. In the areas such as the hood, a trunk or like most cars (& newer trucks) where the outer panel is attached to the inner structure or beam...a urethane sealer/adhesive is the right goop for the job. Lorne
turbo1
Re: Hood question
August 19, 2010, 09:37:33 pm »
I hear what your saying.. can you recommend what I or we should use ? Just as a matter of interest I did check into the panel bond from 3m and the applicator gun... wow is that expensive in Canada.. $56.00 for the panel bond + $175.00 for the applicator gun...I gotta find another option so im open to whatever ideas you have..
three8six
Re: Hood question
August 19, 2010, 09:59:52 pm »
We welded mine no joke. It didnt burn off the paint on the top. We did repaint the top anyways though just because of a color change. That was just my ONE single experience though.
txchainsawgogi
Re: Hood question
August 19, 2010, 10:02:09 pm »
New hood? Mine is doing the same thing...I was going to fix it but there's a bit of rust on it aswell, so I'm just going to replace it.
Re: Hood question
August 19, 2010, 10:26:32 pm »
The right stuff RTV will do the trick - fast cheap fix
turbo1
Re: Hood question
August 20, 2010, 12:28:32 pm »
The right stuff is not a urethane seam sealer/ adhesive. Did you try it on your hood ?? How well did it bond the two pieces together ??
Swims350
Re: Hood question
August 20, 2010, 12:55:56 pm »
what about silaprene it's supposed to be for that junk, like door skins and crap and not a panel bonding adhesive as they told me it was. it goes in a normal caulk gun and is a good glue I guess, but don't expect to hold replacement panels in with it without it cracking thru body work.
www.cardomain.com/id/benwa454
bobcooter
1979 Scottsdale C-20
Re: Hood question
August 20, 2010, 03:17:33 pm »
[/quote]
Slam panel???
Bitzer!
Smiles per gallon
Re: Hood question
August 20, 2010, 03:33:24 pm »
It's what we call it over here. It's the panel that bolts to the top of the rad core. The hood latching mechanism is bolted to it and the hood "slams" shut on it. I had to separate mine for some rustoration
Body, Glass & Paint
Hood question
