Author Topic: 94 S10 BLAZER cpi  (Read 12235 times)
94 S10 BLAZER cpi
« on: September 11, 2010, 03:53:34 pm »
Well its running like crap alot of fuel in the oil :'( and now only half the engine is firing all one bank the drives side. Sound like the spider injector to you?
Offline 454ss
  • I WANNA RACE IN A BIGFOOT TRUCK!
Re: 94 S10 BLAZER cpi
« Reply #1 on: September 11, 2010, 04:05:54 pm »
Yes.
Jay
Searching for my ideal 1973-87 fullsize.
1982 C10 Custom Deluxe stepside - traded
1977 C10 Custom Deluxe longbed - junked
Current:
1991 Chevy S10 Blazer 4x4
1995 Olds Silhouette
2009 Chihuahua
« Reply #2 on: September 11, 2010, 04:20:51 pm »
That is not cheap lol
« Last Edit: September 12, 2010, 03:29:06 pm by Captkaos »
« Reply #3 on: September 11, 2010, 04:55:34 pm »
Forgot to say that its smoking bad but its pretty much fuel coming out that's all you can smell
« Reply #4 on: September 11, 2010, 04:59:06 pm »
The EGR is probably sticking open. If it's the injector a fuel pressure gauge will reveal that quickly.
Offline 454ss
« Reply #5 on: September 11, 2010, 10:17:46 pm »
That sob is not cheap lol
Hence why I went with a TBI 4.3... ;D
Jay
Current:
2009 Chihuahua
« Reply #6 on: September 11, 2010, 11:06:27 pm »
Those little clues that you forget to mention. but also when I try to turn it over it seams like once it hits a cylinder or two it wants to lock up almost like hydro lock but if you turn the engine by the crank then hit the key again it will rotate slowly(think the starter is week and due to the engine problem it isn’t helping). Not familiar with the spider but is it possible that one side be all screwed up and the other side be fine. How would a tester show if it the injector? I understand how to test the pump but not sure about the injector
Offline 454ss
« Reply #7 on: September 11, 2010, 11:09:04 pm »
you can check the cpi unit by taking the vortec cover off and removing the black circular part underneath it (the imtv) this is the easiest way to check the cpi unit because the other way to check it is to remove the whole intake plenul (which is required to chance the cpi unit)
but when you remove the black circular piece you will be able to look inside the intake plenum. it should have grime and some crud in there (or be dark in color). if it is clean and shiny on one side and not the other, that would indicate a fuel leak, there were some pictures i found a few weeks ago that were a great example of what it should/should not look like, ill see if i can find some of that info again.
i dont know the name of the company offhand but they make a replacement cpi unit that is supposed to be better than the factory one.
one last thing i just thought of, is most of the time you will hear people refer to the cpi unit as the "spider" but they also refer to the "nut kit" which is also located under the intake plenum (should be near the fuel rail that enters in the rear of the plenum)and this can leak too causing some problems.
Jay
Current:
2009 Chihuahua
« Reply #8 on: September 11, 2010, 11:19:26 pm »
makes sense about the leak. i think i did read something about it but it said something that the fuel would drip back to the passengers side
« Reply #9 on: September 12, 2010, 12:06:00 am »
this should help me
http://blazerforum.com/forum/showthread.php?t=1374
now all i have to do is check my brothers to see if this is the problem almost sounds like it
« Reply #10 on: September 12, 2010, 08:41:08 am »
Check the fuel pressure - if it's bleeding down pinch the return line. If it's still bleeding down you know the injector is done for. It's more common for the egr to stick open due to carbon though so check that as well.
