Author Topic: brakes to close  (Read 12777 times)
Offline rroeder96
brakes to close
« on: September 14, 2010, 11:09:35 am »
my brake caliber i noticed is to close to my rim (i think) i run 35x12.5x15 and i noticed my calibers are real close to my rims i want to know if this is normal or is this ok thanks.....
Offline Psycho71
Re: brakes to close
« Reply #1 on: September 14, 2010, 03:58:11 pm »
What kind of truck? 3/4ton? 1/2ton?
Re: brakes to close
« Reply #2 on: September 14, 2010, 04:06:31 pm »
They typically are close.  If they don't hit you are probably fine...
Offline rroeder96
Re: brakes to close
« Reply #3 on: September 14, 2010, 04:12:53 pm »
the truck is a 1/2 ton
Re: brakes to close
« Reply #4 on: September 14, 2010, 04:21:16 pm »
     What if any is the backspacing of the rims ?
Offline rroeder96
Re: brakes to close
« Reply #5 on: September 14, 2010, 04:25:47 pm »
im not sure what the back spacing is on if there is any...
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
Re: brakes to close
« Reply #6 on: September 15, 2010, 01:26:32 pm »
How close are they?  I'd be fine with 1/4"  .
Offline rroeder96
Re: brakes to close
« Reply #7 on: September 15, 2010, 04:38:44 pm »
i would say they are about the thicknes of a quarter between the rim and the caliber if ever that far apart...
  • Z62 ON-ROAD
Re: brakes to close
« Reply #8 on: September 15, 2010, 08:36:57 pm »
You got steel or aluminum wheels?   I don't know the answer but maybe somebody else will chime in, I would say that would be fine AS LONG AS the wheels never ever flexed.   But they will flex some and i don't know which (aluminum or steel) would flex more, or if it would even be a problem.  I would assume it't a problem until told otherwise.  If it was me, I wouldn't like it just because I don't know about the wheels.
Offline rroeder96
Re: brakes to close
« Reply #9 on: September 15, 2010, 08:57:20 pm »
the wheels are aluminum i have noticed today when taking a closer look the the top of the caliper had hit the inside of the rim and made a full circle around the rim so no im concered about this problem i dont want to get bigger rims so if anybody has a clue please let me know thanks for all the help....
Re: brakes to close
« Reply #10 on: September 15, 2010, 10:44:24 pm »
Why don't you actually look to see what's rubbing and where by jacking it up and spinning the wheel? All anyone can do here is guess. Wheel weight? Wasted wheel bearing? Caliper falling off? etc etc
Offline rroeder96
Re: brakes to close
« Reply #11 on: September 15, 2010, 10:57:37 pm »
i can see where its rubbing, i done jacked it up to see now im left guessing why its so close to the rim and what i can do to fix the problem besides going to bigger rims. i posted this topic to see if anybody else had this problem that might be able to help in any little way thanks for everybodys help....
Offline jaredts
Re: brakes to close
« Reply #12 on: September 16, 2010, 05:31:20 am »
Is this truck or the wheels new to you?  I'm just wondering whether its the geometry of your wheels or some other problem.  It can be close without ever touching if everything is pretty tight.  I had an occassion once where bad ball joints turned a close fit with an aluminum wheel to scraping and gouging when the wheels were turned.  Is it equally close on both sides?  Would a wheel spacer get it out of the way?
Re: brakes to close
« Reply #13 on: September 16, 2010, 08:57:44 am »
What kind of wheels are they?  Factory, aftermarket?  If they are hitting, what are they hitting the actual rim?
You won't need "bigger" wheels, you need wheels with better spacing on them.
Where did they come from?
Offline rroeder96
Re: brakes to close
« Reply #14 on: September 16, 2010, 02:15:56 pm »
yeah the truck and rims are all new to me they are micky thompson rims the tires are 35x12.5x15 so im guessing the rims are 12.5 deep i dont know if wheel spacers would work or not i have two that spacers that came off my minitruck i had im sure if they will work i will try and see. i dont like them cause i hear alot of bad stories about them falling off while driving so they kind of worry me but its worth a try...thanks for your help...
