Author Topic: Paint  (Read 8241 times)
Offline colebra
Paint
« on: October 14, 2010, 07:11:16 pm »
Hey guys I am new. I just bought a 79 and needs a little more body work but overall it's almost ready for paint. I was thinking maybe black with a white stripe on the hood or a metalic burgandy/red. If you guys couls send some pics of some neat paint I would love it thanks!! :)
Brad Cole
Offline 74on40s
Re: Paint
« Reply #1 on: October 14, 2010, 08:07:07 pm »
c.a.r.c military olive drab. Oil based paint so it wont rust out like normal :) and it's really easy to cover up scratches
1983 GMC K30 Crew Cab aka " Hillbilly Shortbus "
1968 302 zapper motor pushin 425hp
D60/14bff 4.10's
th400/ np205
25" of total lift
49" swampers
Pure Fun to drive
Re: Paint
« Reply #2 on: October 14, 2010, 10:08:39 pm »
Way cool looking rig!
Offline N2TRUX
Re: Paint
« Reply #3 on: October 15, 2010, 08:05:55 am »
Welcome to the forum  colebra. How about a factory style two tone?
Offline colebra
Re: Paint
« Reply #4 on: October 15, 2010, 08:33:22 am »
Thanks for the posts guys. I was thinking more of a black truck maybe with pinstripes.
Offline Grim 82
Re: Paint
« Reply #5 on: October 15, 2010, 08:54:50 am »
This has always been one of my favorite paint schemes. Not my truck, just a pic from the web:
Re: Paint
« Reply #6 on: October 16, 2010, 11:11:20 am »
Not a fan of the white top but that's a nice truck!
Offline westsidek20
Re: Paint
« Reply #7 on: October 16, 2010, 12:00:19 pm »
i know I'm probably going to get hammered and thrashed with this post, since i know most of you guys wouldn't touch your trucks by anything less then the best, and have extremely good paintjobs, BUT Ive seen some people use rustoleum, because its more "rust resistant" then other paints.... any comments?  ???
Re: Paint
« Reply #8 on: October 16, 2010, 09:48:11 pm »
There is nothing special about rustoleum... just a fancy buzzword trademarked name.  WD-30 helps resist rust.  Some paints are better than others but you get what you pay for.  The main key is the prep work.  It all depends on your budget and intended use.  A good etching wash primer followed by a good 2K epoxy primer for starters.  Then a good 2K primer surfacer which would be block sanded straight.  Then a good 2K primer sealer followed by whatever topcoat system you choose.  The best paint in the world is only as good as the base it is put on.  Most problems are from the inside out or repairs made were not done right.  I am not a body man nor paint cars, I just have worked in the paint field for 25+ years and the industries I serve need corrosion protecting which require salt spray and prohesion testing.  There are so many paint specs out there for different applications from immersion service, marine atmosphere, yacht to aerospace, jets, military.  Sorry if I get passionate sometimes but I had to throw in my $.02
Offline Grim 82
Re: Paint
« Reply #9 on: October 16, 2010, 09:57:02 pm »
zieg85 pretty much summed it up. It all starts with the prep work. I've never used rustoleum, I've only used PPG base/clear but when I paint my truck in the future, I'm using Dupont Nason. I can get it cheap and some friends of mine have done great work with it that has stood up for quite a while. I won't say that X brand is better than the other, because everyone has their own great results with something that somebody else thinks is garbage, but I will say that the best paint in the world won't last if the prep work is poor.
Offline westsidek20
Re: Paint
« Reply #10 on: October 18, 2010, 03:03:34 pm »
Great responses you guys.  8)
