Author Topic: 454 project  (Read 4427 times)
Offline kayster
454 project
« on: November 13, 2010, 01:28:12 pm »
Hello..I have a 81 Chevy C/20 regular cab long box, I just bought a 454 out of a 1975 motor home..This is my first project like this so I'm looking for some good advice from people..I got the motor stripped down to just the block and I'm ready to start building it. I'm shootin for 600+ hp and I'd like to stick to pumped gas. I plan on strokin it to a 496. What I'm looking for is some advice on the heads I'm gonna need to achieve the 600+..I've been told everything from 294cc intake runner size all the way up to 325cc, Oval port and rectangle port has been recommended...I need to get some good accurate advice on this..Ill probably go with Brodix or Dart..Can someone here help me out..?
Thanks
Re: 454 project
« Reply #1 on: November 13, 2010, 01:59:04 pm »
If you are going aftermarket heads I like the Edelbrock performer rpm oval ports
Offline kayster
Re: 454 project
« Reply #3 on: November 13, 2010, 07:06:04 pm »
hey thanks for the articles, ill check them out..
Offline Engineer
Re: 454 project
« Reply #4 on: November 14, 2010, 11:38:06 am »
What heads do you have now?
Look at your casting numbers.
If your head casting numbers end in 049, or 781, then you have some awesome GM factory heads capable of 700+ HP with port work, and larger valves with a hyd roller on 496ci.
I am making 550hp on 049s with stock ports, intake gasket match, 2.19in/1.88ex valves, and a solid flat tappet cam on 461ci.
« Last Edit: November 14, 2010, 11:42:11 am by Engineer »
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Offline kayster
Re: 454 project
« Reply #5 on: November 14, 2010, 11:56:58 am »
their off of a 75 motorhome...
