Author Topic: vent window frame  (Read 13373 times)
Offline 84c20
vent window frame
« on: November 15, 2010, 11:07:39 am »
Does anybody make a new vent window frame for a 73-87? The hinge is broken on one of mine. Thanks
Offline ccz145a
Re: vent window frame
« Reply #1 on: November 15, 2010, 11:32:08 am »
gm still sells them.
« Reply #2 on: November 15, 2010, 11:36:26 am »
Chris can get you one. You can get them in tinted or clear. Basically all new replacements are 1985 up style which will work but may look different if your truck is the older style.
They aren't cheap though, you can probably buy a parts truck cheaper
http://forum.73-87chevytrucks.com/smforum/index.php?topic=9726.0
Offline eventhorizon66
« Reply #3 on: November 15, 2010, 01:00:50 pm »
Are you talking about the the lower pivot point?  Mine broke too.  I was planning on removing the frame to see what I could rig up (maybe just drill it out and run a bolt through it).  I don't want to replace the thing because I never use it, but I do need to fix it.
If you are talking about the upper hinge, did the whole hinge break off or did the rivet just break?  You can replace just the rivet.
'85 C10 SWB 350 700R4 TKO600
« Reply #4 on: November 15, 2010, 03:02:29 pm »
discontinued from GM
Offline 84c20
« Reply #5 on: November 15, 2010, 04:28:44 pm »
The whole upper hinge is shot. The metal around the rivet is rusted up and cracked.
« Reply #6 on: November 15, 2010, 06:07:55 pm »
Get a used one. I have replaced the rivit, I have also welded the bottom pivot back on to several of them.
Offline 1980c10
« Reply #7 on: November 15, 2010, 06:54:49 pm »
expensive to get a new one. definatley worth looking for a used one. If I remember right 200+ per side wherever I seen them.
Offline topp
« Reply #8 on: November 15, 2010, 09:05:05 pm »
Try watching Craigslist for parting out...
Got 2 of 'em for my 87 for under $20....
Had decent seals to...No whistleing...
'90 Suburban TBI 350
Offline 84c20
« Reply #9 on: November 16, 2010, 09:46:33 am »
I guess ill look for a good used one then. My seals are ok so thats not too important right now. Thanks
Offline jaredts
« Reply #10 on: November 16, 2010, 11:52:08 am »
You want to find one with good seals so you just slap it in.  Swapping your seals over wouldn't be fun.  If you were close to Kentucky I'd give you one of my spares.  Finding one should be really easy and cheap though.  Pulling it would be the hard part if the door is all together.
