Author Topic: sm465 tranny help!!  (Read 3595 times)
Offline sphnyx991
sm465 tranny help!!
« on: December 27, 2010, 08:36:12 pm »
so i have a 1984 chevy 3/4 ton 4x4 that had 6.2, i swaped the blown diesel and bought a new chevy zz4 350 crate motor that i just dropped in today. i installed a brand new gm flywheel, a brand new hayes super truck clutch kit, a new gm roller pilot bushing, and a the new throwout bearing that came with the clutch kit. so i went to put the tranny back in after i dropped the motor in and i cannot get the tranny in all the way... i can get it within 1 1/2 inches to the bell housing and cannot get it to slide all the way together. is there something iam doing wrong here? the pilot bushing had a rounded edge on it so i put that edge towards the input shaft thinking it will aid it going together. i was using a floor jack and will be getting a tranny jack and hope this will help enough to get it together... any ideas here or any of you had this problem before? i fought this thing for a couple hours today and gave up
Re: sm465 tranny help!!
« Reply #1 on: December 27, 2010, 08:45:54 pm »
Did you align the clutch disc? Did you match the splines on the clutch disc to the input shaft?
Offline frogman68
« Reply #2 on: December 28, 2010, 01:55:22 am »
If what Ville wrote is correct I would think the angle of the engine and trans is off.
The sm465 is a heavy one I would of put it in as a single unit (engine and trans).
Not sure if this will help/work what I do is get some 1/2 thread by 4 or 5 inches cut the head off screw them into the bellhousing and use them as guide pins.
Stop pushing the trans when its about two inches out and adjust the angle , once its right the trans should slide right in
