Alignment shims looking odd
Topic: Alignment shims looking odd (Read 4373 times)
GUITAR1989
January 08, 2011, 02:49:17 pm »
Hey guys check these out and tell me what you think...should it be even on both sides? also some are sticking out higher than others..could they pop out and cause major problems?
Re: Alignment shims looking odd
January 08, 2011, 02:51:18 pm »
No they should not be even. I always use new shims of the same size so it doesn't look like that but as long as they are torqued they are fine.
GUITAR1989
January 08, 2011, 03:08:22 pm »
ah right on i just thought they might be pushing out. So its ok that theres a different number of shims on the driver side than the passanger side?
January 08, 2011, 03:11:27 pm »
Yes, this is how you set your camber and caster
