Author Topic: adding a transmission drain plug  (Read 9636 times)
Offline 1984k30
« on: January 24, 2011, 03:00:19 pm »
I am going to change my tranny fluid and filter and want to put a drain plug in.  I got one at my local parts store but am worried about it giving me problems.  My main concern is that it just has a o ring on the bolt you screw in. It does not have a stop and the more you tighten it the o ring will just crush maybe causing it to fail over time.  The bolt is not a pipe thread so I don't think teflon tape will help?  Anyone use one and not have a problem with it leaking.  I may just weld a nut to the pan and get a oil pan bolt and gasket and use that.
Offline jaredts
Re: adding a transmission drain plug
« Reply #1 on: January 24, 2011, 03:54:35 pm »
The o-ring should hit and collapse some small amount...like .030" and then the head or something else should bottom out.  If it truly does just crush the o-ring more and more its not properly designed.  There should be an oring groove in the nut piece to take up like 75% of the o-ring's thickness if I'm picturing it correctly.  I guess you could take an old oil pan and cut the sheet metal and weld it to yours.  I think there was a post recently somewhere on here with a link to a pan that had a drain plug.  Seems like it would be worth a few bucks to save you all the trouble.
Offline 1984k30
« Reply #2 on: January 24, 2011, 05:00:31 pm »
I think the groove is what it needs.  I think I will take it to a friend of mine and him put it on his lathe and cut a groove in it.
« Reply #3 on: January 24, 2011, 11:11:22 pm »
They usually leak. What trans do you have? You'd be better off with an aftermarket pan.
Offline 1984k30
« Reply #4 on: January 24, 2011, 11:24:05 pm »
It is a 4l60.  I seen b&m makes a pan but not sure I want to spend 200.00 on it right now.  I thought I could get away with a ten dollar drain plug kit but may not be worth it if it starts leaking and I end up having to buy another pan because I drilled a hole in mine.
Offline TexasRed
« Reply #5 on: January 24, 2011, 11:49:52 pm »
http://www.summitracing.com/parts/TCI-378011/
that's just 2 min of searching. I didn't check to see if that's the cheapest.
Offline Layne
« Reply #6 on: January 25, 2011, 01:11:18 am »
My B&M 2in deeper pan leaks, so maybe a drain plug isn't a good idea. Unless mine is  bad...
« Reply #7 on: January 25, 2011, 05:23:03 am »
you can get the gasket thats on oil pan drain plugs for a couple cents at the auto store. and do what you said get a similar size bolt and nut weld the nut on and be done
Offline 1984k30
« Reply #9 on: January 25, 2011, 10:38:20 pm »
Vile do you think that pan would be ok?  Seems like it would be china junk to me.  Seems like every one I ever talked to about cheap chrome engine oil pans always said they leaked but I'm up to giving it a shot.  Maybe the expensive ones are made in china too? Also what kind of gasket to you think is best to use.  cork, rubber, paper or garlock material.
« Reply #10 on: January 25, 2011, 11:33:22 pm »
i have one that is either summit or jegs brand, it is cast aluminum and has thick flanges to help against leaks. I like it and it has a drain plug.
Offline Dr_Snooz
« Reply #11 on: January 26, 2011, 12:00:30 am »
Why don't you just use a crush washer? I've tried orings before. They don't seal at all. As soon as a little heat builds up inside the case, it will push that oring right out of the way. A crush washer will work real well. Alternatively, you can just slather a normal washer up with some RTV. That also seems to work very well.
« Reply #13 on: January 26, 2011, 10:04:03 pm »
« Reply #14 on: January 30, 2011, 01:19:32 am »
     The pan in Beastie's link looks like it is done right and would not have any problems sealing.  looks stout too.
