adding a transmission drain plug
Topic: adding a transmission drain plug (Read 9641 times)
1984k30
January 24, 2011, 03:00:19 pm »
I am going to change my tranny fluid and filter and want to put a drain plug in. I got one at my local parts store but am worried about it giving me problems. My main concern is that it just has a o ring on the bolt you screw in. It does not have a stop and the more you tighten it the o ring will just crush maybe causing it to fail over time. The bolt is not a pipe thread so I don't think teflon tape will help? Anyone use one and not have a problem with it leaking. I may just weld a nut to the pan and get a oil pan bolt and gasket and use that.
jaredts
Re: adding a transmission drain plug
January 24, 2011, 03:54:35 pm »
The o-ring should hit and collapse some small amount...like .030" and then the head or something else should bottom out. If it truly does just crush the o-ring more and more its not properly designed. There should be an oring groove in the nut piece to take up like 75% of the o-ring's thickness if I'm picturing it correctly. I guess you could take an old oil pan and cut the sheet metal and weld it to yours. I think there was a post recently somewhere on here with a link to a pan that had a drain plug. Seems like it would be worth a few bucks to save you all the trouble.
1984k30
January 24, 2011, 05:00:31 pm »
I think the groove is what it needs. I think I will take it to a friend of mine and him put it on his lathe and cut a groove in it.
January 24, 2011, 11:11:22 pm »
They usually leak. What trans do you have? You'd be better off with an aftermarket pan.
1984k30
January 24, 2011, 11:24:05 pm »
It is a 4l60. I seen b&m makes a pan but not sure I want to spend 200.00 on it right now. I thought I could get away with a ten dollar drain plug kit but may not be worth it if it starts leaking and I end up having to buy another pan because I drilled a hole in mine.
TexasRed
January 24, 2011, 11:49:52 pm »
http://www.summitracing.com/parts/TCI-378011/
that's just 2 min of searching. I didn't check to see if that's the cheapest.
Layne
January 25, 2011, 01:11:18 am »
My B&M 2in deeper pan leaks, so maybe a drain plug isn't a good idea. Unless mine is bad...
January 25, 2011, 05:23:03 am »
you can get the gasket thats on oil pan drain plugs for a couple cents at the auto store. and do what you said get a similar size bolt and nut weld the nut on and be done
January 25, 2011, 09:59:05 pm »
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=330423628673&viewitem=
1984k30
January 25, 2011, 10:38:20 pm »
Vile do you think that pan would be ok? Seems like it would be china junk to me. Seems like every one I ever talked to about cheap chrome engine oil pans always said they leaked but I'm up to giving it a shot. Maybe the expensive ones are made in china too? Also what kind of gasket to you think is best to use. cork, rubber, paper or garlock material.
beastie_3
Josh
January 25, 2011, 11:33:22 pm »
i have one that is either summit or jegs brand, it is cast aluminum and has thick flanges to help against leaks. I like it and it has a drain plug.
Semper Fi
Dr_Snooz
"I like to take hammers, and just break stuff"
January 26, 2011, 12:00:30 am »
Why don't you just use a crush washer? I've tried orings before. They don't seal at all. As soon as a little heat builds up inside the case, it will push that oring right out of the way. A crush washer will work real well. Alternatively, you can just slather a normal washer up with some RTV. That also seems to work very well.
January 26, 2011, 08:16:53 pm »
That was just a cheap one I would at least use an aluminum one like this
http://cgi.ebay.com/ebaymotors/GM-700R4-POLISHED-ALUMINUM-TRANSMISSION-PAN-8493-_W0QQcmdZViewItemQQhashZitem4cefa7c348QQitemZ330438263624QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
beastie_3
Josh
January 26, 2011, 10:04:03 pm »
Mine...
http://www.summitracing.com/parts/SME-1008R/
Semper Fi
bake74
January 30, 2011, 01:19:32 am »
The pan in Beastie's link looks like it is done right and would not have any problems sealing. looks stout too.
74 k10, 77k10 Tom
