Author Topic: cheapest/easiest way to lower a c10  (Read 32654 times)
Offline txchainsawgogi
« on: February 06, 2011, 04:32:57 pm »
just want it to sit a little lower but dont want to go crazy with the mods...just a few inches. im going to put my cragars on soon and that'll help a little.
78 c10 long bed.
Offline slammed79
  • Thou shalt not drive stock
Re: cheapest/easiest way to lower a c10
« Reply #1 on: February 06, 2011, 08:35:18 pm »
2" Spindles in the front, then shackles and hangers for the rear. A nice simple 2/4 drop.
I've been seeing spindles on Craigslist for $100 and less, shackels and hangers would be about $120 depending on the source. Plus $65-80 for drop shocks for the back. Drop shocks aren't needed on spindle only drops because you aren't changing the distance from the mounting points.
Praise the lowered
Offline bluasdac
« Reply #2 on: February 07, 2011, 08:12:49 am »
I wonder what it would look like with just using 2" shackles in the rear???  I'm sittin on 22's but don't want an extreme drop either...
Offline slammed79
« Reply #3 on: February 07, 2011, 10:46:11 am »
A shackle drop in the rear would prolly look killer with your 22's. It help fill in any gap in the wheel well.
Praise the lowered
« Reply #4 on: February 07, 2011, 04:43:49 pm »
any how to's around here on doing these? i've never lowered a vehicle.
Offline slammed79
« Reply #5 on: February 07, 2011, 04:54:23 pm »
Its primarily just swap one part out for another, the hangers in the rear take some work because of the rivets. Also if you do a flip kit, you need to measure, cut and drill your frame. I'll do a write up with pictures when I do my 74 in a few months.
Praise the lowered
Offline 1980c10
« Reply #6 on: February 07, 2011, 05:59:11 pm »
for 2" in front you would be a little better off just getting the 2" lowering springs.
« Reply #7 on: February 07, 2011, 06:52:28 pm »
are these parts model specific or just kinda universal?
Offline 1980c10
« Reply #8 on: February 07, 2011, 08:16:15 pm »
order the parts specific for your truck.
Offline bluasdac
« Reply #9 on: February 08, 2011, 09:07:38 am »
yea thats what I was thinkin goin with the rear shackle...guess i'll get to ordering because im ready to drive my truck again!
Offline rwhit57
« Reply #10 on: February 08, 2011, 12:43:32 pm »
When you use the longer shackle hanger in the rear, you have to notch the bed brace just above it for clearance.
Randy from Okla
Whoever said "Money can't buy happiness" has obviously never seen a speed shop!
Online Captkaos
« Reply #11 on: February 08, 2011, 01:41:08 pm »
And hangers typically need the pinion angle checked.
Offline bluasdac
« Reply #12 on: February 08, 2011, 02:10:53 pm »
man this sounds like i need to get some professional HELP and I'm a pretty mechanical guy..
Online Captkaos
« Reply #13 on: February 08, 2011, 02:20:11 pm »
just pointing out some of the gotchas.  You should be fine.
Offline bluasdac
« Reply #14 on: February 08, 2011, 08:44:06 pm »
know of any threads with pics?????  might try to do this weekend??
