Author Topic: Frame brace/strengthening  (Read 10583 times)
Offline Elpresidente
« on: February 15, 2011, 10:15:22 am »
Ive got an '82 Chevy K10, and I was thinking that this year I may want to make the frame a bit more rigid.
Does anyone know of any methods to do so, by either welding or bolting-on supports at certain spots on the frame?
Thanks.
'82 Chev Scottsdale
Proud to be Canadian \m/
Offline Grim 82
Re: Frame brace/strengthening
« Reply #1 on: February 15, 2011, 10:57:01 am »
The frame brace kit sold for the steering box area would be a good upgrade.
« Reply #2 on: February 15, 2011, 11:21:37 am »
There are many things you can do however some frame flex is good and prevents unnecessary stress... What are you trying to achieve?
Offline thirsty
    • Suitor's Garage
« Reply #3 on: February 15, 2011, 04:49:58 pm »
I agree with Vile, if it doesn't flex it will probably break easier. A bare frame with nothing on it is alot more flexible than you would think.
I would only brace it where they tend to crack where stuff is bolted on like the steering box.
Offline junkman.
« Reply #4 on: February 21, 2011, 12:56:42 pm »
Well frame flex is good in the right places but when GM & dodge went from the sector shaft coming out the side of the box to the bottom now these frame are failing from flex in this area not good so if your frame has not cracked yet a strut style brace will be best if you frame it cracked  you could use a weld in plate type.
On my LB frame the frame is broke almost all the way around the box on my SB frame its good I'm going to make two struts that mount off the box bolts   well good luck JM
