Author Topic: Need some help where to start  (Read 7492 times)
Offline jameswoodlee
« on: February 20, 2011, 08:13:58 pm »
Sooo I have a 77 C10 and a 85 C10 stepside. Wanting to get both trucks redone. My 77 is basically done needs a paintjob and a new set of wheels. My 85 needs alot more work inside and out engine and suspension and everything. Where is a good place to start on either truck. I am really wanting to get the ball rollin on either one, tired of having both of those in the process but not done. Both have 350 and turbo 350 trannys. I am wanting both lowered and just bad  looking. Would love some ideas or any kinda of help to get me started I just need someone to point me in the right direction Please help!!!!!!!
« Last Edit: February 20, 2011, 08:30:31 pm by jameswoodlee »
Wood
Re: Need some help where to start
« Reply #1 on: February 20, 2011, 09:03:02 pm »
If you trust your 85, I would finish the 77 first. Then you can completely focus on the 85.
« Reply #2 on: February 20, 2011, 09:07:02 pm »
What would you start on exactly though. Like how would you start out on the project??
Wood
Offline slammed79
  • Thou shalt not drive stock
« Reply #3 on: February 20, 2011, 11:07:00 pm »
The 77 is pretty clean, I'd prolly bag it and put some larger diameter wheels on it.  The stepper, just static drop it and call it a day.
Praise the lowered
« Reply #4 on: February 21, 2011, 12:10:09 am »
It depends on where you will be doing the work I suppose. With the 85 I would remove the bed, cab, and drivetrain. Then clean up the frame, install the suspension, and engine. It will be very convenient to work on it with the cab and bed removed. Then focus on the bed and cab.
Bring me your 77 because a truck with 49er colors needs to be in Cali...especially in Santa Clara where the 9ers are moving...
« Reply #5 on: February 21, 2011, 09:16:46 am »
   ;D never hurts to try, hey beastie .
« Reply #6 on: February 21, 2011, 11:06:26 am »
lol ok ill drop my truck off for ya  ;D. I think im going to order a bigger cam for my 77 and just get it repainted and new wheels and be done with it. The stepside will probably be a ground up restoration to make it how I want it. Im just ready for these things to be done
Wood
« Reply #7 on: February 21, 2011, 02:46:23 pm »
Sounds like a good start. If your going to tear down the front clip to paint the 77, that will be the best time to do the cam swap since nothing will be in the way. Unless your thinking of pulling the engine to do it.
« Reply #8 on: February 21, 2011, 08:01:15 pm »
yea im hoping to get a start real soon.
Wood
« Reply #9 on: February 21, 2011, 08:10:40 pm »
How about some bigger pics and more detail on what you want to accomplish. They look pretty clean from those baby pix.
« Reply #10 on: February 21, 2011, 08:45:38 pm »
well they both need to be repainted I want the 77 a wild color just something that will stand out and catch everyones eye. I want the stepside more of a beast want it lowered with a big bad ass sounding engine. both will get basically some of the same things lowered etc new paint and wheels i just dont know where is the best place to start.
Wood
« Reply #11 on: February 27, 2011, 03:57:17 pm »
fix the body rot issues and rough body work, tear it down, set up your suspension, put together your powertrain, Install the fresh new looking body, put in the interior and drive. You should have it done in about a 1/2 hour or so  ;)
Offline devanray
« Reply #12 on: March 01, 2011, 09:36:37 pm »
Whatever you do, make sure the step-side bed has some nice stained wood and chromed strips! Remember, that bed makes that rig what it is, those cabs are on everything. Go for one of those 'changes in the light' kinda paint jobs, lots of pearl in it.
Also, if you want the looks, put on some smoke stacks! Turn her into a little red wagon, but better, because yours wears a bow-tie!
"Before removing any bolts, read through the entire procedure."
Offline devanray
« Reply #13 on: March 01, 2011, 09:43:54 pm »
Here is a great example of the bed.
