Author Topic: Valve spring question  (Read 2897 times)
Offline thachevythang
« on: February 23, 2011, 01:55:25 am »
Surely a newbie question but trying to get all the right parts ordered for my build.
I have new heads that support a .520 lift. Valve springs and retainers included. As long as my cam selection does not exceed that amount of lift, I don't have to order new springs correct?
'85 SHORTBED
Offline Gusgus74
Re: Valve spring question
« Reply #1 on: February 23, 2011, 01:46:02 pm »
You need to multiply the cam lobe lift by your rocker ratio to determine the true lift at the spring. I would still mock up a solid lifter, pushrod and rocker and spin the motor one revolution to verify if the spring is binding.
« Reply #2 on: February 23, 2011, 03:41:17 pm »
Valve springs need to meet the cam manufacturers specifications as well as be installed at the correct specifications.
