Engine/Drivetrain
Swap question on am465
Topic: Swap question on am465 (Read 4580 times)
bake74
March 01, 2011, 02:41:36 pm »
Will a sm465/np 208 from a 85 blazer bolt into a 77 k10 that had a sm 465 in it ? I wanted to know if the linkage is the same as with the transfer case cross member, if it would be just a straight bolt in or not. I searched but could not find an answer here, thanks in advance. Tom
74 k10, 77k10 Tom
Grim 82
Re: Swap question on am465
March 01, 2011, 03:19:29 pm »
My guess is that the crossmember location, driveshaft lengths, and t-case shifter would be different, but not sure. Do you have the t-case shifter and the driveshafts from the np208 truck? Probably simple to do, but probably not a straight bolt in...
bake74
March 01, 2011, 04:30:14 pm »
The 85 is complete, since the 77 got it all stolen I will have to get the shifters and mounts also.
74 k10, 77k10 Tom
1980c10
March 01, 2011, 05:19:20 pm »
The '85 should have a hydraulic clutch linkage the '77 is mechnical. It can be converted to hydraulic but would require some modifications. I guess it depends what parts you have. Do you have the linkage for the '77?
Grim 82
March 01, 2011, 06:33:33 pm »
If the 85 is complete, you should have most everything you need for the swap. As near as I know, to keep the mechanical clutch setup you would just need to swap the front clutch housing/bell housing portion on the trans with a mechanical bellcrank style one. Hydraulic would be a good upgrade though if you have all the parts.
bake74
March 02, 2011, 06:11:02 pm »
They took the fly wheel, bell housing, trans and trsnfr case, and all the linkage, so I will have to check into going hydraulic as an upgrade or find something else. Thanks for the answer's.
74 k10, 77k10 Tom
Engine/Drivetrain
