General Discussion
Charging problem
Topic: Charging problem (Read 4608 times)
BULLDOG
Charging problem
March 06, 2011, 04:12:32 pm »
I have a 83 k20 that I bought off a 16 year old who didnt have the money to work on the truck.
The alt. is not charging the battery so I looked down at the starter and there is some very creative wiring lots of old eletrical tape with new tape around it multiple splices with wire nuts held off the headers with a piece of pipe.
So,I cut off that mess and now I have it hooked up like this pos bat cable to large stud red wire from alt little red wire from alt and main power feed to truck on large starter stud and purple wire to little stud on starter .
How many wires from the engine harness should go to the large stud on the starter.
Black 1983 K20 and sm 465
Re: Charging problem
March 06, 2011, 06:44:08 pm »
What about your fusible links? I've posted the correct schematic many times showing how it should be set up if you search.
⌠ŻŻŻŻŻ' [☼===☼]
BULLDOG
March 06, 2011, 07:06:59 pm »
the larger and small red wires and the main power feed the the truck are run threw a fusable link from the larger starter stud.
March 06, 2011, 07:47:32 pm »
http://www.73-87chevytrucks.com/techinfo/wiring_diagrams/81-87_V8_engine.jpg
⌠ŻŻŻŻŻ' [☼===☼]
BULLDOG
March 06, 2011, 08:21:33 pm »
so brown wire to 12 v key on source large wire from alt stud to large stud on starter so where does the small red wire from alt go?
1980c10
March 06, 2011, 10:27:21 pm »
from the stud the wire from the stud will go to your distribution block(on the firewall) with a fusible link in between. from there power travels to the starter and back to the battery. Essentially this wire feeds the battery(the long way). btw this wire may skip the dist block or even possibly the starter but this is the typical path.
-with the neg cable disconnected; test continuity from the alt stud to the pos battery post/cable. when you have continuity here you have most likely solved your problem.
to find the problem;
-test cont from the alt stud to the dist block
-test cont from the dist block to the starter
-check fusible links, wires and connections where you find don't have continuity.
-If you need to replace any of the circuit it is important to use the correct size wire and size of the fusible link
BULLDOG
March 07, 2011, 07:17:10 am »
this truck has had some very creative wiring done there is no dist block but does anyone know the part number for the distrubution block?
I have the large red wire from large stud going to large stud on starter I also have the small red wire from side of alt going to large starter stud is this correct I have not hooked up the battery and tried any of this yet
1980c10
March 07, 2011, 08:02:58 pm »
Sounds like it should work to me, make sure your wires are in good shape and not spliced together etc, also make they have the fusible links installed. The dist block is not needed.
General Discussion
Charging problem
