Author Topic: Center support bearing  (Read 7078 times)
Offline 1979C20
  • Kyle Taulton.
« on: March 15, 2011, 03:10:37 am »
The rubber on my center support bearing is MIA. The bearing fell infron of the bearing case and the driveline nelted/deteriorated the case almost all  the way through before I got the money to replace it. I picked up a bearing today and removed my front shaft and carrier from the truck at the slip joint and tranny. We tried a bearing press, but my dad didnt feel comfortable tightening it anymore without something breaking. We cut the outer race with a port-a-band saw pryed it off and took the bearings out. We tried cuttong the inner race with a brand new blade, it barely scratched it. We cant get it off no matter what we tried. Hes out of acetylene, and I have no way to take it to a shop. Any suggestions? Im desperate.
Offline former520
Re: Center support bearing
« Reply #1 on: March 15, 2011, 06:31:14 am »
I used a cut off wheel on a 4" grinder.  Cut a slot all the way through and used a large flat blade screwdriver to spread it apart a little and it fell right off.
87 Regular Cab Classic Deluxe 20, 350TBI, TH400, 2wd
Offline slammed79
  • Thou shalt not drive stock
« Reply #3 on: March 15, 2011, 10:37:23 am »
I'd just buy the whole unit as well, after messing with trying to change just the bearing once, I swore never again. Irish is right, its only a couple bucks more, if any. The Checker I worked at on Elsworth and Main didn't even sell just the bearing alone.
Praise the lowered
Offline 1979C20
  • Kyle Taulton.
« Reply #4 on: March 15, 2011, 03:47:20 pm »
I bought the whole thing. Im trying.bb you to get the old one off! Haha.
Offline 1980c10
« Reply #5 on: March 15, 2011, 05:56:43 pm »
me too
« Reply #6 on: March 15, 2011, 10:32:52 pm »
Need one of these and put the shaft into an arbor press.
« Reply #7 on: March 15, 2011, 10:40:44 pm »
Use a press or a vice. Protect the splines with some tape. If you have no access to heat carefully cut a slit in it with a die grinder. You'll get it.
Offline 1979C20
  • Kyle Taulton.
« Reply #8 on: March 16, 2011, 04:08:25 am »
Okay, once I got up today and it wasnt 1 o'clock in the morning, I grabbed the pneumatic cutoff wheel and cut the inner race a little more than halfway through then shoved a fat chisel in the cutand after 2 smacks with a hammer the race cracked and I was able to tap it off with a hammer. New one is installed and good to go. My dad was out of acetylene so we couldnt torch it.
