Author Topic: did GM not galvanize this area?  (Read 9609 times)
Offline 87swb
« on: March 17, 2011, 09:40:38 pm »
i put a new bulb in my cargo light and i can see i have some of that very light surface rust in between the inner and outer panel of my roof. is there anything i can do?
Offline topp
Re: did GM not galvanize this area?
« Reply #1 on: March 17, 2011, 09:56:54 pm »
Most of your truck is not galvanized.
'90 Suburban TBI 350
Offline Edahall
« Reply #2 on: March 17, 2011, 10:04:17 pm »
Yes, spray some por-15 with a spray gun in there.
1990 ¾ ton 4x4 Chevy Suburban
-Gear Vendors Overdrive
-Upgraded Holset HX-35 turbo
-NP205 iron transfer case
-3.73 gears
-2" Lift
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #3 on: March 18, 2011, 07:54:10 am »
Only galvanizing I've ever see was on the front disc brake splash shields... :)
Offline topp
« Reply #4 on: March 18, 2011, 07:55:42 am »
In '89 GM started galvanizing these trucks a bit.
« Reply #5 on: March 18, 2011, 08:36:14 am »
There is a product called Spray-Galv in a rattle can by Seymour paints.  I'll see if I can get some more info on it and post it up.
http://www.seymourpaint.com/spray_galv.html  while finding it there are many others that offer the same type of coating.
« Last Edit: March 18, 2011, 08:41:46 am by zieg85 »
« Reply #6 on: March 18, 2011, 11:37:55 am »
You need to prevent oxygen and moisture from penetrating the unprotected area. Once oxygen and water gets in there any sheetmetal will start to rust. Air has moisture in it so just being exposed to damp air will rust unprotected sheet metal. There are so many products on the market now, just google "stop rust"
Offline 87swb
« Reply #7 on: March 18, 2011, 08:27:05 pm »
i'm talking about the wrong thing then, what ever they coat the metal underneath the truck with, it's gray looking. it should be in there. i'll try to spray something. thanks for the replies, i know i get a little obsessed about rust on here. just trying make it last. i'm beginning to believe there is no such thing as a rust free older chevy.
Offline Edahall
« Reply #8 on: March 19, 2011, 12:07:46 am »
Yeah, I feel your frustration regarding rust.  Although rare, there's a few rust free older Chevy trucks out there such as my Suburban that spent its life in the California desert.  On the otherhand, my other Suburban (1982) spent its life in Washington state where it rains a lot and it's rusting from the inside out.  I've tried many times to deal with it but it keeps coming back with a stronger vengence.  It's now a lost cause so eventually, the drivetrain will be taken out and put into a newer vehicle.
-3.73 gears
-2" Lift
Offline 87swb
« Reply #9 on: March 21, 2011, 09:24:38 pm »
everything on my truck is solid except for a few palces in the windshield channel and back glass. no cab corner or rocker rust. only thing i figure is if its rusting from the inside out is because of condensation. heavy dew from overnight making it sweat on the inside of the panels.
« Reply #10 on: March 22, 2011, 03:54:24 pm »
Floor pans were galvanized in 1983.
Offline 87swb
« Reply #11 on: March 22, 2011, 08:05:37 pm »
well i think it helped out a lot when they done that
