Author Topic: Rearend Swap  (Read 4692 times)
Offline Baron
Rearend Swap
« on: March 27, 2011, 07:33:20 am »
Has any one done a rearend swap from drum brakes to disc? My truck is a 76 model. If so what rearend did u use?
Re: Rearend Swap
« Reply #1 on: March 27, 2011, 08:19:30 am »
Need allot more info. 2 wheel, 4 wheel drive? 1/2, 3/4, 1 ton?
There are some kits you can buy to upgrade to rear discs. I know a few guys that have made the brackets and used front discs and calipers.
Offline 79chevykid
Re: Rearend Swap
« Reply #2 on: March 27, 2011, 08:29:40 am »
Im buiding a 79 2wd and i looked into doing a full axle swap, the only thing is there isnt a ton of cars with the 5x5 bolt pattern. and my 12 bolt is in good shape so im going with the conversion.
1979 short box chevy custom deluxe (project)
Re: Rearend Swap
« Reply #3 on: March 27, 2011, 09:58:00 am »
Baron you need to empty your in box. I just sent you a reply to your message and it won't go as your in box is full!
Offline Toolmaster
Re: Rearend Swap
« Reply #4 on: March 27, 2011, 10:09:48 am »
And stop reporting this post to Moderator .  Click reply !!
Re: Rearend Swap
« Reply #5 on: March 27, 2011, 10:13:15 am »
I have four reported posts by baron for no apparent reason.... what's the problem ?
Offline Baron
Re: Rearend Swap
« Reply #6 on: March 27, 2011, 10:14:01 am »
thanks Toolmaster
