Rearend Swap
Topic: Rearend Swap (Read 4702 times)
Baron
Rearend Swap
March 27, 2011, 07:33:20 am »
Has any one done a rearend swap from drum brakes to disc? My truck is a 76 model. If so what rearend did u use?
Blazin
Blazin new trails!
Re: Rearend Swap
March 27, 2011, 08:19:30 am »
Need allot more info. 2 wheel, 4 wheel drive? 1/2, 3/4, 1 ton?
There are some kits you can buy to upgrade to rear discs. I know a few guys that have made the brackets and used front discs and calipers.
79chevykid
Re: Rearend Swap
March 27, 2011, 08:29:40 am »
Im buiding a 79 2wd and i looked into doing a full axle swap, the only thing is there isnt a ton of cars with the 5x5 bolt pattern. and my 12 bolt is in good shape so im going with the conversion.
1979 short box chevy custom deluxe (project)
Blazin
Blazin new trails!
Re: Rearend Swap
March 27, 2011, 09:58:00 am »
Baron you need to empty your in box. I just sent you a reply to your message and it won't go as your in box is full!
Toolmaster
Re: Rearend Swap
March 27, 2011, 10:09:48 am »
And stop reporting this post to Moderator . Click reply !!
Hang him !!! (Judge Roy Bean) Looters will be shot on site !!!
Re: Rearend Swap
March 27, 2011, 10:13:15 am »
I have four reported posts by baron for no apparent reason.... what's the problem ?
Baron
Re: Rearend Swap
March 27, 2011, 10:14:01 am »
thanks Toolmaster
Rearend Swap
