Author Topic: Multiple distributor questions...  (Read 4538 times)
Offline dstark
« on: March 28, 2011, 07:21:23 pm »
I have a '76 C20 350/350 4BBL Quadrajet. The carb on the truck has many vacuum lines plugged off. According to the manual, one of the vacuum lines goes to the vacuum advance for the distributor, but the distributor on the truck does not have a vacuum advance port.
Can I put a new distributor on with a vacuum advance port? Also, when trying to buy a distributor, it asks for w/governor or w/o governor? Where do I look to know if I have a governor?
Thanks for any help you can give.
1976 Chevy C20 350/350/4.10 4BBL Qjet
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
Re: Multiple distributor questions...
« Reply #2 on: March 29, 2011, 09:18:33 am »
Empty out your inbox dstark.  I can't send you any PM's.   ::)
Offline royo
« Reply #3 on: March 29, 2011, 11:23:02 am »
A regular 4 pin hei would work fine for you . You would put it on a vacuum source that increases with rpm
« Last Edit: March 30, 2011, 07:12:44 pm by royo »
Offline dstark
« Reply #4 on: March 30, 2011, 12:36:18 pm »
That's weird. I only had the one PM from you. I'll try and get a pic up soon of the distributor I have.
