Author Topic: painting emblems  (Read 68576 times)
Offline PromiseKeeper
painting emblems
« on: April 20, 2011, 08:45:26 am »
I found a set of pretty nice set of fender emblems for my '80 C-10. While cleaning them up. what little remained of the yellow paint inside the lettering washed away. Maybe someone here has redone a set that could give me a couple of pointers. Is there any kind of prep required prior to painting? Is this a rainy Saturday afternoon project with a small brush, or is there a quicker way to do a good job? Who can tell me a color code for this, or what kind of paint would work best? Thanks guys and gals!
Scott
Online Captkaos
Re: painting emblems
« Reply #1 on: April 21, 2011, 10:20:31 am »
Paint would be the GM Ochre
Offline bake315
« Reply #2 on: April 25, 2011, 10:11:05 am »
Scott
I'm in the process of refinishing my emblems as well.  Being as the emblems are chromed, I don't know how well anything will stick.  I'm trying a rattle can etching primer to see how well that does. Going to do the GM Ochre/Argent Silver/Black on the Cheyenne Super badges, then Ochre/Cardinal Red/Black on the Camper Special badges, then finally Ochre/Omaha Orange on the 3+3 badges.
• '73 Cheyenne Super C20 454/400 http://forum.73-87chevytrucks.com/smforum/index.php?topic=7672.0
• ’79 Scottsdale K10 350/NP208/SM465 “Oscar” http://forum.73-87chevytrucks.com/smforum/index.php?topic=37885.0
« Reply #3 on: April 25, 2011, 04:48:42 pm »
bake,
I ended up going to a hobby shop and talked to someone there about what I would need. They thought the Testor's enamels would be the way to go. Cost $1.49 a bottle. Interestingly they didn't have them and sent me to Discount Drug Mart to get them. Evidently it is because they sell models. Of course it wasn't a perfect match, but really came out nice. They didn't feel that primer was needed, but I'm sure it wont hurt. Are you masking it and spraying?  :o :o That will be quite a feat! I guess worse case, I'll just have to redo mine if it comes off.
« Last Edit: April 25, 2011, 04:50:13 pm by PromiseKeeper »
Offline bake315
« Reply #4 on: April 30, 2011, 10:48:26 pm »
bake,
Well, I'm definitely going to try the masking/spraying route, and I expect to attain a whole new level of tedium in the process! ::) I'm not at all sure that I can brush it on and be happy with the results (although when I get to the camper special badges I may have no choice).  I have some 454 Chevelle badges that I painted first with an etching primer, then a yellow that starts to approach the ochre (called Equipment Yellow).  While the paint was still fresh, I cleaned away the paint on the edges using lacquer thinner and a combination of tooth pics and Q-tips.  I'll post up a pic of those in a couple of days.  One thing I wanted to do that I've been unable is to paint and then topcoat it with clear.  I've found that unless I've got many coats (or a couple of really heavy ones) the clear penetrates the paint and causes it to lift, effectively ruining it.  :(
I have some spray stencil ink that I'm using while porting my heads... I can get several coats that are very thin... I may play around with that some this week.
« Last Edit: May 01, 2011, 09:39:36 pm by bake315 »
Offline bobcooter
  • 1979 Scottsdale C-20
« Reply #5 on: May 01, 2011, 08:41:53 pm »
I've some times wondered if you couldn't "insert" the paint with a hypodermic needle?
Offline bake315
« Reply #6 on: May 01, 2011, 09:29:35 pm »
That's an intriguing idea.  While I guess you could draw paint into a syringe from custom-mixed paint from the paint store, it might be more cost effective to perhaps buy it in smaller "touch up" quantities that are premixed...  Possibilities abound!
« Reply #7 on: May 02, 2011, 08:12:23 pm »
The lady at the craft shop sold me an awesome paint brush that went down to a really small point and was semi stiff. It was just the ticket to paint the emblems. I probably did them both in about an hour.
« Reply #8 on: May 02, 2011, 10:16:13 pm »
     Where's the pics promisekeeper ?  :)
« Reply #9 on: May 03, 2011, 07:30:30 am »
I'll have to take the camera next time. It's not at the house. I get so into what I'm doing and have thought several times I should have taken a pic of what I'm doing.
Offline bake315
« Reply #10 on: May 04, 2011, 11:26:12 am »
You sir, are preaching to the choir! :D
Offline JohnnyCanuck
« Reply #11 on: May 04, 2011, 08:48:12 pm »
I double that.  I was thinking about doing the same so can't wait to see how yours turned out.
Offline 79chevykid
« Reply #12 on: May 04, 2011, 09:34:35 pm »
so i painted one of my old emblems tonight just to see what it would look like, i did it black with the inside red. i remembered to take some pictures along the way too,first i sanded it alittle to get the rough edges off then i sprayed the whole thing with some krylon bbq and stove high heat black and then used testors model paint on the inside using a toothpick. i like how it turned out
forgot to take a befor pic but the others are pretty much the same minus a 1
1979 short box chevy custom deluxe (project)
« Reply #13 on: May 04, 2011, 10:05:57 pm »
nice job....wheres the number one?
Offline 79chevykid
« Reply #14 on: May 04, 2011, 10:10:38 pm »
it the original emblem and the one was missing when i bought the truck but i got another one so i have 2 good ones. that was just practice to see how it would come out
