73-87 Chevy & GMC Trucks
starting problems
Topic: starting problems (Read 9885 times)
73ratrod
starting problems
May 01, 2011, 12:31:37 am »
.........________//__{\_____
,,,,,,,,,/__(O)__/____/_(O)_/chevy
beastie_3
Josh
Re: starting problems
May 01, 2011, 12:35:12 am »
it could be your starter, but does it turn over slower or not at all? OR it could be ignition or vapor lock too. you have to give us more details.
Semper Fi
73ratrod
May 01, 2011, 02:26:03 am »
it turns over like it wants to fire but doesn't catch
i have new starter and battery
and when i turn the truck off after being warmed up the butterfly on my carb stays open intal it cools down
May 01, 2011, 03:08:47 am »
whats the starter have to do with fire. unless its turning over slow
RCCoors
May 01, 2011, 09:27:42 am »
Don't know about yours but my 77 350 had that same problem. It finally stopped starting altogether and it turned out to be the ignition module. It was getting weaker as it warmed up until it quit. Changed it and haven't had a problem since.
77' C20 350/TH350 4.11 14Bolt FF
May 01, 2011, 09:55:48 am »
When you make a post select new topic not new poll. Your description of what's happening isn't very clear. Which symptom sounds like what's happening:
Engine cranks normally but does not start when warmed up.
Engine cranks slowly resulting in hard start when warmed up.
73ratrod
May 01, 2011, 10:47:09 pm »
where do u think the ignition mod would be located on my truck ima have to take a look into that
Last Edit: May 01, 2011, 11:02:59 pm by 73ratrod
May 02, 2011, 10:41:11 am »
you just cant look at it most time if the icm goes it will die not, not start when warm tell us what its doing. so we can help before you start spending money on parts you dont need
73ratrod
May 02, 2011, 07:11:33 pm »
like ive said im drive the truck around for about 20 min ill shut the truck off and go into the store for about 5 min and come back out to start her but shes turning over real slow and weak, but after she kools down the starter will have enough juice to start right up
May 02, 2011, 09:50:32 pm »
see you never said the starter turns over real slow just wont start. but anyway could be just timing is advanced too far or the starter is getting week and the heat aint helping i would go with the timing first since its free to adjust
beastie_3
Josh
May 02, 2011, 09:52:50 pm »
How old is your battery?
Do you have a stock starter? How old is it?
Does it turn over so slowly that it wont start, or does it start but just turns over slowly?
Semper Fi
bake74
May 02, 2011, 10:14:18 pm »
Have you checked the teeth on the flywheel.
74 k10, 77k10 Tom
73ratrod
May 02, 2011, 10:45:40 pm »
battery and starter are brandnew and it turns over slowly that it wont start and the flywheel is fine cuz its not skipping, ill check the timing though thanks for all the advice im only 16 so all this is new
the guy we got it from pulled the 350 and put a 305 in we dont know what the motor came out of but the starter is for a 86 elcamino
beastie_3
Josh
May 03, 2011, 12:06:42 am »
a starter is a starter unless they are built depending on compression, but i dont think so. someone will confirm or bust it.
Semper Fi
May 03, 2011, 08:58:31 am »
Yup on that starter question
starting problems
