Author Topic: Rochester quadrajet 4bb 305 engine  (Read 13412 times)
Offline bowdown916
« on: May 15, 2011, 10:19:39 pm »
Sup guys.. I been looking around for a rochester quadrajet 4bb.. does anyone know where can I find one online for a good price?
I was wondering if anyone knows if this carb. # 17085526 its for a 2bb or 4bb?
Sent from my DROIDX using Tapatalk
Offline snibook7537
  • Vince Ziolkowski
Re: Rochester quadrajet 4bb 305 engine
« Reply #1 on: May 16, 2011, 02:29:07 pm »
The forum has said a lot of good things about this guy, http://www.smicarburetor.com/products/sfID1/28/sfID2/9/sfID3/32/productID/18. I have never used a carb he sells but I am going to in the future when I do an engine swap.  He seems to have a pretty good reputation around here.  I don't know if you want to drop over $300 into a 305 but you aren't going to beat the MPG's of a Quardajet if you go to a Holley.  The Q jet is one good carb.  I believe the carb you have listed is a Quardajet so yeah it's a four barrel.  Just wondering why you want a new car also? Why not just rebuild yours.
1984 Fiero se pwr windows Holley TBi, cam, 86 5spd
1987 GMC V3500 350 TBi 4spd 205 t-case
Shoulda never sold:
1976 c-10 beater 250-6 4spd no pwr steering, brakes. Recycling truck
Offline bowdown916
Re: Re: Rochester quadrajet 4bb 305 engine
« Reply #2 on: May 16, 2011, 06:35:50 pm »
I was told that carb. 17085526 its a 2 bb. And that I needed a 4bb carb.. how I know if I have a 2bb carb or 4bb?
Offline bowdown916
« Reply #3 on: May 16, 2011, 09:02:41 pm »
thats my carb.. 17085526, but when i search for it online,i cant find it..
Offline TexasRed
« Reply #4 on: May 16, 2011, 09:52:31 pm »
That's a four barrel.
Looks like it's computer controlled too.
Offline bowdown916
« Reply #5 on: May 16, 2011, 10:12:54 pm »
i been doing alot of search. and none of the 2 barrel looks like my carb.. not sure why the mechanic said that i had a 2 barrel and i need it to get a new 4 barrel carb...
Offline bowdown916
« Reply #6 on: May 16, 2011, 10:14:31 pm »
where can i find that same carb. online? i dont get much when i type in the carb. number.. do i need to use the rochester carbs or can i use different brands?
Offline DrDaryl
« Reply #7 on: May 16, 2011, 10:35:42 pm »
I did a search on one of the companies that sells remanufactured carbs and that is an E4ME quadrajet 4 barrel.  Used electronics to control the mixture more closely for emissions.  That carb looks mighty clean I wonder if it is a reman unit that someone put on your truck?  Using adapters you can put just about any carb you want on your intake.
Offline bowdown916
« Reply #8 on: May 16, 2011, 11:07:10 pm »
I bough the truck like 3 weeks ago. and the last owner said he rebuild the carb. like 6 months ago. he said,but few days later i checked the paper work where he took the carb. to rebuild and it was last year, around june, and they only give 6 months warranty,so i would have to have someone check it to see if somethig its really wrong with the carb. one of the mechanics said that it was wasting to much gas or something like that... the problem with the truck and that it wont run fast how it suppost to... it seens that it takes like a minute to get up to 65mhp... if i push the gas and wont take off like a regular truck/car, it will kinda take his time to get up to speed lol ... engine sounds good.everything looks fine thats what mechanic said...so the 2 things i gotta check now its that carb. to see if something its wrong with it and probably change the catalytic to get it smog too...
« Reply #9 on: May 16, 2011, 11:10:14 pm »
Sounds like your mechanic is wasting oxygen too. Start with the basics
Offline bowdown916
« Reply #10 on: May 16, 2011, 11:22:03 pm »
i was thinking on taking the truck to a carb. shop for second opinion  :)
Offline bowdown916
« Reply #11 on: May 17, 2011, 08:10:58 am »
How many times can a carb be rebuild?
Offline bowdown916
« Reply #12 on: May 17, 2011, 05:52:17 pm »
I took off the carb. today from my truck, i noticed the fuel line had a big kink on line by the fuel filter, also theres few sensors and where the electronic choke connector has a zip tie :) ...
maybe theres nothing wrong with my carb...
Offline bowdown916
« Reply #13 on: May 17, 2011, 06:49:45 pm »
anyone know where can i find some connectors for the ones i need to replace for thr carb.?
