Author Topic: Issue with reverse lights  (Read 10946 times)
Offline K20Wulf
« on: May 19, 2011, 03:22:18 am »
Okay, so the problem is; when I put my truck in reverse I can wiggle the column shifter and they will go on and off. I know it's probably a connection of some sort, but know idea of which one or how I would go about fixing it. Any help would be much appreciated.
86 K20 4x4
7" lift, 35's
350/400/208
Offline jaredts
Re: Issue with reverse lights
« Reply #1 on: May 19, 2011, 08:00:58 am »
Could just need an adjustment on your neutral start switch.  Is there a lot of slop in the shifter?
« Reply #2 on: May 19, 2011, 09:53:02 am »
Offline Grim 82
Offline jaredts
« Reply #4 on: May 19, 2011, 01:15:28 pm »
Stupid?  I resemble that remark.
« Reply #5 on: May 19, 2011, 01:33:46 pm »
me 2  ;D
Offline K20Wulf
« Reply #6 on: May 19, 2011, 02:43:20 pm »
Thanks guys, I'll try and climb under there before work and see if I can adjust it. :)
86 K20 4x4
7" lift, 35's
350/400/208
« Reply #7 on: May 19, 2011, 04:43:49 pm »
its on your steering column
Offline K20Wulf
« Reply #8 on: May 20, 2011, 05:42:53 am »
I meant climb under the dash. With the height of my truck it's literal, lol.  ;)
86 K20 4x4
7" lift, 35's
350/400/208
« Reply #9 on: May 20, 2011, 10:02:58 am »
lol, it will take you a while to try and find it under the truck, you might need a torch
Offline K20Wulf
« Reply #10 on: May 26, 2011, 04:44:03 pm »
I totally forgot to answer your question... In reverse there is a decent amount of slop. Not so much in the other gears (I think).
86 K20 4x4
7" lift, 35's
350/400/208
Offline jaredts
« Reply #11 on: May 27, 2011, 05:43:47 am »
Easiest and most likely culprit is still probably an adjustment of the neutral start switch.  Have you tried that yet?  Eliminating slop in the shifter may be something you have to tackle, but I doubt it and I really can't help much with that.  The detents are in the transmission, so sloppy only in reverse may not be fixable anyway.  This is an automatic right?
Offline K20Wulf
« Reply #12 on: May 28, 2011, 05:32:16 am »
Yep, Th400. And sloppy in all gears, think it's in the column because the trans is perfect.
« Last Edit: May 29, 2011, 12:12:44 am by K20Wulf »
86 K20 4x4
7" lift, 35's
350/400/208
