Author Topic: TH350: no reverse, no drive?  (Read 21895 times)
Offline kmcbride74
« on: May 27, 2011, 10:29:40 am »
Vehicle: 1985 silverado c10 1/2 ton 2wd.  Just put in 74 350 with th350 from it that worked fine in the truck it came from.  I drove it, so it was not a scam.
I split the tranny and engine when doing my engine work.  I put front, rear, and shifter seals in the tranny.  After completing the engine, bolted up the tranny, ensuring the TC snapped into place.
I replaced the fluid and filter last night, no gears, no reverse, no drive.  Any thoughts on what this might be?  I read up some on here and will try the Lucas tranny fix if nothing else pops up...
Kurt
Re: TH350: no reverse, no drive?
« Reply #1 on: May 27, 2011, 10:36:03 am »
Did you bolt the convertor to the flexplate? Is the linkage hooked up? Is the fluid level correct? Are you sure you safely engaged the pump?
Offline kmcbride74
« Reply #2 on: May 27, 2011, 10:57:44 am »
Thanks for the quick response!  Answers in-line below...
Did you bolt the convertor to the flexplate? Yes.
Is the linkage hooked up? Yes.
Is the fluid level correct? Yes.
Are you sure you safely engaged the pump? By this, you mean when putting the converter back on after front seal change, yes, I think so, I mean, I didn't clam it on, but eased it on, turned it until I heard is sort of snap/click into place.
Offline kmcbride74
« Reply #3 on: May 27, 2011, 11:45:16 am »
Even if the there is a root cause I'm missing, is there any harm in putting the Lucas in the tranny?
« Reply #4 on: May 27, 2011, 12:12:48 pm »
did you hear two clunks or just one when you put the tc in?
Offline jaredts
« Reply #5 on: May 27, 2011, 01:11:30 pm »
Lucas won't fix your problem.  Did you fill your torque converter with transmission fluid before putting it in?  Embarrased to say I've made that mistake many moons ago.
Offline kmcbride74
« Reply #6 on: May 27, 2011, 01:13:11 pm »
hmmmm, was a number of days ago and beverages ago. :)  I think maybe just one.  Should there be 2?  Is there any easy way to confirm its in there properly after its already in the truck and bolted up?  Or do I need to unbolt it and back it up from the engine to confirm?
Offline kmcbride74
« Reply #7 on: May 27, 2011, 01:13:54 pm »
I was told this is not necessary since it is not a lockup th350?
Offline jaredts
« Reply #8 on: May 27, 2011, 01:29:02 pm »
Someone will correct me if I'm wrong, but I believe every torque converter needs filled up on any automatic transmission before install.  Right or wrong my Dad called a friend when I did it and he said to let it idle to fill the converter, but there would be a risk of burning up the pump.  It idled for almost an hour before everything worked correctly, but I never had a problem after that.  This was on a front wheel drive Nissan that was very difficult to do a transmission change on.  In your case (assuming I'm correct) you'd be better off to just put some long bolts from tranny to engine and slide the tranny back enough to get the converter off and fill it.  Other than a few swaps I'm no transmission guy, so someone please confirm this.
« Reply #9 on: May 27, 2011, 01:36:06 pm »
You should always prefill the converter. How much fluid did you put in? Did you flush the cooler before you installed this trans? What was wrong with the old one?
« Reply #10 on: May 27, 2011, 01:36:58 pm »
If you're sure everything is correct, drop the pan and inspect the filter and the manual valve.
Offline kmcbride74
« Reply #11 on: May 27, 2011, 01:39:15 pm »
I filled the pan to th high mark on the dipstick, I have the cooler line fittings plugged off for the moment, I sold the old tranny, its gone, it was slipping
Offline kmcbride74
« Reply #12 on: May 27, 2011, 01:39:45 pm »
Put a new filter on it last night.
Offline jaredts
« Reply #13 on: May 27, 2011, 02:55:26 pm »
You have the cooler lines plugged or looped into each other?  I'm not sure transmission fluid will circulate properly if they are plugged.  Is there a good reason to not hook it up correctly?
« Reply #14 on: May 27, 2011, 03:17:33 pm »
Flush out your old cooler and make sure there's no garbage in there. Hook up the cooler lines. You shouldn't even try running it without the cooler lines hooked up.
