Author Topic: rear  (Read 2640 times)
Offline chevy821
rear
« on: June 02, 2011, 09:11:26 pm »
putting my 12 bolt back together i went to put the new albern carrior in an its vary tight so i meshered the carriors an the albern 4serious is about 42thounds longer then the 3 serious eaton. my ? is can the 2 thick spacers be changes to be 22thounds thinner or am i missing somthing  any help would be good thanks
Re: rear
« Reply #1 on: June 02, 2011, 10:53:21 pm »
K - spell check first
Second - are you saying you just replaced the carrier? In other words you are using the same ring and pinion just new carrier bearings? You need to set up at bare minimum the proper side to side clearance for proper bearing preload and set your backlash. From there do a gear tooth contact pattern analysis. You should have purchased a shim assortment kit and some gear marking compound as well. You will need a dial indicator with a secure base.
Offline HAULIN IT
Re: rear
« Reply #2 on: June 02, 2011, 11:35:55 pm »
You will need to tell us more about what you are doing...3 series & 4 series? Did you change the ring & pinion?
The problem at this point is: Do you know where the .042 difference is? If it's all from the ring gear mounting face to the Right side, you will likely need to remove thickness from the Right shim pack, however if it's some here & some over here...you will likely need to subtract some from each side. There are quite a bit of variables in what your working with. As Vile mentioned, you should have some specialty tools & varying thickness shims. Reider Racing had some nice sandwich style shims that you take apart & insert the thin shims in the center, making it MUCH easier to get them in...I believe they went out of business though, maybe someone else makes the same idea. The "spell Check" button will make it a little easier to sort out what your trying to do, which will result in more accurate answers more quickly. Good Luck, Lorne
