Author Topic: Dupont Nason  (Read 11686 times)
Offline Engineer
Dupont Nason
« on: June 26, 2011, 08:08:25 pm »
Has anyone used DuPont Nason?
I am looking at using the Nason 491-35 Ful-Poxy primer/sealer. Follow that with the Nason Ful-Base, and finally top coating it with Nason 498-00 clear.
According to the Nason 491-35 T/M the primer/sealer can be applied to bare metal. It doesn't mention anything about using an etch primer on the bare metal before applying the 491-35. Specs list application using an HVLP gun, which is all that I have.
I am looking at simplicity, and this looks to be it.
Does anyone have any experience using this system?
Is it as simple as it sounds?
I was looking on a hot-rod forum, and some guy was laying out a paint job using Nason that required 13+ steps. I am not into that. I want to strip the old finish, fill some imperfections, clean, and prep, prime, and then fog the new coat on.
What say y'all?
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
Re: Dupont Nason
« Reply #1 on: June 26, 2011, 10:46:10 pm »
If you strip the entire old finish you will need some sort of etching primer, or epoxy primer followed by a high build urethane primer. Sand the urethane, with 320 or finer, and paint.
I have used Nason primers, and paint before. Thet arent bad for the buck.
Offline jaredts
Re: Dupont Nason
« Reply #2 on: June 27, 2011, 05:22:05 am »
Blazin's right.  Your current plan is to use epoxy primer (491-35) and then base, clear.  Epoxy is great on bare metal, but you really should put on a high build primer and block sand before adding base/clear.  You might think everything is perfect, but without that step it will likely look like a kid did the work.  Plan on spending a little extra time and money for a high build primer (probably a 2k urethane) after the epoxy.
Offline Engineer
Re: Dupont Nason
« Reply #3 on: July 03, 2011, 01:50:13 pm »
Thanks for the replies.
After some looking about, here is where I am at now. Following you guy's recommendations I have added 2K urethane to the processes....
1)Strip paint from body, apply wax/grease remover.
2)Fix minor body imperfections, dents, etc.
3)Nason 491-35 epoxy primer/sealer. DuPont says 1 coat, or 2 if looking for more corrosion protection.
4)Follow that with Nason 421-19 gray 2K urethane primer. Dupont recommends more thin coats as opposed to a couple thick coats to prevent trapping solvent.
5)After the 2K urethane I plan to allow it to dry in order to block sand. DuPont recommends 400 or finer. Wet, or dry. I'm thinking wet.
6)Treat once more with wax/grease remover.
7)After the block sand I look to put on the Nason Ful-Base 430-xx, as many coats as needed to get color, let it flash, then apply Nason 498-00 overall, multi panel clear.
I have read where the bodywork should be done OVER the epoxy primer, and under the 2K urethane, but I prefer to do the body work directly to the steel, then coat.
Please opine. Tell me what to do different.
Re: Dupont Nason
« Reply #4 on: July 03, 2011, 03:25:59 pm »
Why do you want to strip it? Just take care of the bad areas and sand the whole body. Prime, block, paint
Offline Engineer
Re: Dupont Nason
« Reply #5 on: July 03, 2011, 04:21:01 pm »
Since the fenders, doors, hood, and bedsides are late production.....bedsides are off of an '82, the rest is from a 1991 Suburban, I probably won't strip those.
However, the cab has much steel work to be done, and it has been repainted before. The GM paint is long gone. In just a couple of test scuffs I found the top coat to be laying directly over sheet metal. I'll just feel more at ease with a totally bare cab to start.
Re: Dupont Nason
« Reply #6 on: July 04, 2011, 07:14:48 am »
I do my body work over bare steel as well. Just how I was taught 20 plus years ago.
 More thin coats are better than a couple heavy coats.
 As far as block sanding if you have allot of waves or are looking to get it supper strait I recommend 3 to 4 mils plus of urethane primer, then guide coat, and block sand it with 180, then 220. Then apply 4 plus mils of urethane again. Then wet sand with 400 and 600 grit paper
